OFNA X3 GT SERIES
#453
no idea on stiffer shock springs?
#454
I've been on the fence about this thing for a LONG TIME. And now IGT has their kit which basically looks like a hopped up x3 (correct me if I'm wrong). What are the known issues with this car that I should take care of right away? I
Is that IGT8 car worth it?
#455
I've run this car all season with not many breakdowns, pretty quick.
#456
To me the IGT is basically all the options that Hong Nor and some others make added to the basic kit, and it comes in kit form. The diff gears are the Sabre buggy version (13/43) as are the engine mounts, and the brake kit is the same as X3S-27 from Hong Nor. But no body, tires etc, just like buying any other high end kit where you choose your own. The roll bar is a great add on but you can see in the pic where the holes were just added to the stock chassis. Their upgrade kit is still cheaper than sourcing all the parts separately though.
#457
I think I'm going with the RTR and go for some speed runs and build it little by little. I have some 4 shoes clutches still left over but what is the clutch bell everyone is going with? I heard about the bearing issues.
#459
Thank you sir. Already ordered a few sets of bearings from AvidRC.
#460
has anyone tried the cnc upper brace? ive added the cnc chassis braces, serrated nuts, rear cvd's......i see i should go 10/12*? caster? Ive got the sweep 50* tyres...anything else? i got a 2650kv mamba max system on the way even though the rtr system is quite impressive....just want my car to be the best
#461
Yes the IGT8 has most of the parts you need. Dual brakes, larger tank, 43/13 gearing, 4 shoe clutch (try 2 carbon, 2 aluminum with lighter spring on carbon) ........ But you should get 10 degree front hubs, which you can use the Ofna aluminum or you can use the plastic Serpent one with just a little work. Body works well, go to sweep tires.
#462
#463
Anyone have a list of bodies that fits this car? The Protoform body work? Or the Ofna viper body?
#464
Nothing?
#465
I have a protoform body otw. I'll let you know how it fits. Most anything with the right wheel base should fit tho
