Serpent 960....
#2236
Originally Posted by avs
i thought that endplay is the float in the clutchbell with all parts installed, and endgap is the float with the bearings removed?
But maybe nigel sets his clutches correct, but we don't understand exactly what he means.....
#2237
Originally Posted by M7H
Yes, so a 0.7mm endplay also to me looks impossible....
#2238
Hi. I have a 960 with some aluminium optionals (alu middle block,alu radio plate support, alu rear bumper) and am using stainless steel M4 screws. I noticed that serpent has aluminium M4 screw kits.
Since my car weights 2.8kg without fuel, i'd like to decrease that so i ask if anyone uses the aluminium screws and don't they get stuck a lot (i mean the head strips and you cant remove them) ?
Thanks for any answer. Also, tips for removing extra weight welcome
#2239
#2240
Originally Posted by Team Kamikaze
A lot of Serpent drivers uses the Aluminum screw kit that Serpent offers, it will significantly drop the weight when using the aluminum screws, and if concerned about the philips head getting stripped, well it won't strip as long as you use the correct size philips head screw driver. and regarding the removal of excess weight in your car, you can use titanium pivot balls in your suspension, change the pivot ball caps to the new nylon ones with part # 803198 and your car's weight will be lighter.
Thanks for the help.
#2241
The stock plastic parts are actually about half the weight of the aluminum "hop-up" parts.
#2243
Originally Posted by michael 1
you can also use the alum. pivot balls from the 720 in the upper arms
#2245
Registered User
What's up mike. Are racing the region12 and the nats
#2246
Registered User
sorry Are you racing the region12 and nats in vegas
#2248
Registered User
I missed the mugen race because of work
#2249
glad to hear youre still in it mayn. Heard you were out of the game!
