Serpent 960.... >
Serpent 960....
Serpent 960....
Old 11-03-2006, 10:08 AM
  #1786
RedRC's Avatar
The dogbone is the driveshaft.
The A Arms are the plastic parts that connect the upper wishbone to the bodymount.
When mounting the rear anti roll bar, first put the 2 blades into their aluminium mount (the part that pivots on the bearings). Then you can either pop the anti roll bar track rods onto the blades or attach them to the blades first and then mount them to the lower wishbone.
I see from the picture that you have the anti roll bar track rods mounted on the new outer most hole. This could be the reason it doesnt mount? See if you can mount it first to one of the two inner mounting holes first.
Also just to make sure that you know that the anti roll bar connects through the opening in the top wishbone?
RedRC is offline
Old 11-03-2006, 12:45 PM
  #1787
i think ive solved it i disconnected the "pin" that is connected to blade and the other mountpoint on the other place...
it was very easy..
but i got some shims/orings left.. and some screws.
dont know what to do with them hehe
maybe something will throw of the car when i am driving or something...
hmm.. my rearbelt is very slack.. i have the belt tensionsetting as "default"
maybe i should tried "tightest"
but i dont know a solution for easy change that belt tension without taking the whole car apart
Orfeous is offline
Old 11-04-2006, 10:17 AM
  #1788
Perez's Avatar
Hey Orfeus, put both belts on the tightest setting. Im glad that you figured out what was wrong with your car because it looked tore up!!
Perez is offline
Old 11-05-2006, 06:52 AM
  #1789
my friend helped me yesterday with some things..
doing some mods today for the 960.. example grind on the carbon body support-plate so its not contact the rear belt in lowest position.
changing some screws and so..
i need to take the car down again!!!
gonna change all wheel bearings to ceramic.. 12x18x4
and maybe buy the titanium pivot balls
My 960 today
http://umea3.mine.nu/gallery2/main.php?g2_itemId=420
Orfeous is offline
Old 11-06-2006, 01:51 AM
  #1790
emankov's Avatar
...hmm..
Hi guys, first try in 1/8 class here
anybody has an easy method to "reset" the MAIN needle of an ZX21 DS2 to "factory settings" (if there is such thing) ?
Although i had "marked" the original position, i mess up counting when trying to "bench run" her.
what can i say i did a silly mistake and i dont expect to be the last...
emankov is offline
Old 11-06-2006, 02:43 AM
  #1791
Default 960 car and parts
does anyone have info on shops in the us or web sights for serpent dealers,
for best prices and service thanks
brad151 is offline
Old 11-06-2006, 04:00 AM
  #1792
M7H
M7H's Avatar
Originally Posted by emankov
...hmm..
The main needle should be flush with the housing, the low end needle should stick out 1-2 mm.....
This is a rich setting.....
http://www.rctech.net/forum/showpost...&postcount=992
M7H is offline
Old 11-06-2006, 06:07 AM
  #1793
nigelnuggets's Avatar
brad you can try Kamikaze Toys and Hobbies. They have the full line of 960 parts and optionals. They always have everything in stock and provide fast and friendly customer service.
give them a call at 714-997-8697. Theyre located in So. Cal, but they ship to where ever its needed. or you can shoot an Email to [email protected]
nigelnuggets is offline
Old 11-06-2006, 07:44 AM
  #1794
also ACE HOBBIES IN NOR-CAL 650-632-4055
960 and 720 parts
michael 1 is offline
Old 11-07-2006, 04:28 AM
  #1795
madbeats's Avatar
Default How's the 960 doing
Originally Posted by C Verano
Yup still kicking just taking care of things at work. I'll PM my current set-up for the CR to you. How's the 960 doing for you?
Edit: Madbeats...Setup is in your PM.
Chris Da super bad fully hop uped is sitting down .. till the new season starts here's are a pic of my team for next year.. still working out and testing some setting.... but all good.
Attached Thumbnails Serpent 960....-team.jpg   Serpent 960....-bottom-2.jpg   Serpent 960....-bottom.jpg   Serpent 960....-top-side.jpg   Serpent 960....-side.jpg
madbeats is offline
Old 11-07-2006, 11:09 AM
  #1796
captian's Avatar
madbeats nice line up even the buggy thinking about having some fun in the dirt too
captian is offline
Old 11-07-2006, 12:50 PM
  #1797
madbeats's Avatar
Default Captian whut up !!!!!!!!!!!
Captian whut up !!!!!!!!!!! man havn't spoken too you for a long time anyway hows things .. yeh man am looking forward too 2007 i spent lots chips on this game so am going all out.... : still looking for one more toy. Thanks for comp............
madbeats is offline
Old 11-07-2006, 01:28 PM
  #1798
C Verano's Avatar
Nice work on the cars.
C Verano is offline
Old 11-07-2006, 02:44 PM
  #1799
My 960 under development
Attached Thumbnails Serpent 960....-11050001.jpg   Serpent 960....-11050002.jpg   Serpent 960....-11050003.jpg   Serpent 960....-11050005.jpg   Serpent 960....-dsc00842.jpg
Orfeous is offline
Old 11-08-2006, 09:57 AM
  #1800
Cool
For all U guys that reported clutches blowing up at the Vegas race..take a look at this!! http://www.mytsn.com/products/desc.asp?prid=4365
gwilli2001us is offline
