Serpent 960....
#1036
Registered User
Wow! What more can be said. Thanks Jeremy
#1037
#1038
Registered User
Thanks Chris. Jeremy's awesome
#1039
Registered User
Chris do you have a template for the protoform. If you do can you bring it when
you come down?
you come down?
#1041
you come down?
you come down?
#1042
new
Here's a couple new things I got today. The new drilled sliding flyweights and the carbon body support.
Here is a description of the new weights..
http://www.mytsn.com/products/desc.asp?prid=4262
#1043
hopefully mine will be in today too .
#1044
i don't understand why there is those flyweights
i drilled 2 holes in the original flyweights........and i have less weight than this optional part
#1045
One other thing that makes these shoes better is the way they pivot, so instead of trailing flyweight, these are pushed out making for a slightly more aggressive clutch. Each of the 3 weights in the set also features a second hole into which the user can screw in a grub screw. This allows the racer to further increase the aggression of the clutch as it engages.
#1046
Getting my 960 ready and was wondering if I should put any spacers behind the flywheel cone,As maybe it will reduce the amount of shims in the thrustbearing carrier. and if so how much shoud I put there
#1047
#1048
Thank you very much chris.How do you set up your clutch?
mike
mike
#1049
mike
mike
#1050
Almost ready
I took the Serpent 960 to my mate Rich to give it a good looking over
He checks it out and made so adjustment for me
It is looking more then likely next weekend I will give it a test run.
Madbeats
Madbeats
