Serpent 960....
#1771
Man your presence is needed
Originally Posted by C Verano
Good..
Just thought I stop in and see what's going on in here.
Chris
Chris
Nevertheless, it is nice to see you check in some time.
However, I have bone to pick with you what’s up with the setup for x1cr
#1773
Originally Posted by madbeats
Hey Chris nice to know you are still kicking.... Man, your presence is sadly over look on this thread.
Edit: Madbeats...Setup is in your PM.
#1774
960 front to rear drive ratio chart
I have just updated the FRONT TO REAR DRIVE ratio chart that I have been giving to those racers that want it. I now have all the Serpent drive ratios included on this chart. If you want a copy of this email
[email protected]
You have to have Excel on your computer to open this file.
[email protected]
#1775
a new part from serpent released if someone havent seen it.
http://www.mytsn.com/products/desc.asp?prid=4365
"Centax support disk alu SPP"
#1776
What am i doing wrong???
look at the rear. it doesnt feel and look correct.
#1777
#1778
960
ygpm
#1779
I can't quite tell from the photo but is that a kingpin that's screwed out of the right rear upper arm?? Following the instructions, have you set all the kingpins to a correct starting point in the rear blocks so the geometry isn't skewed?
I can't remember, but does Serpent have the 'cam' selectors for the rear inside live axle bearings, and if so, are both sides set the same? This can skew the rear end and the rear drive belt badly.
Take a good look again at everything.
#1780
that part that doesnt look and feel good to me is that body support "wing"
i cant flex with arms that i want.. they move until a point then left one stops.. and i can push it down with a "click"
#1781
Sorry for all the questions, just trying to isolate the problem.
#1782
i am not so good to describe in english but :P
i got it working now, but i still have some strange problems... i cant mount the rear antirollbar.. the blades doesnt reach the hole..
wishbones or something is in its way for the "rod" to reach the "body"
so i guess something isnt as it should.
yes, the arms go very easy and smooth when not connected to body support.
the part with pivot balls.. what dies it call? if that is connected everything is going bad. when not connected the arms are smooth and free...
can i take photos of any special angle? or just show my car in webcam live..
no, it doesnt "click" when not connected with pivotballs etc..
where is tha A-arm?
i just cant understand why all this work for putting it together again.. i took it apart yesterday.. but there have only been problems with the most things.. :P maybe its my knowledge that isnt best and memory.. if i had been smart i had took pictures.. but..
where is tha A-arm?
#1784
Originally Posted by michael 1
take the rear dog bones out and see if it is free then , may be the wromg inserts?
#1785
i have localized what "clicked" it was the hmm.. "stays" to the rear antirollbar that scratched on wishbone? dogbone? the black arm lowest..
it seems that it works good now
so, now i am trying to connect the rear antirollbar but i dont know how..
my friend told me that i must do on a special way because i have the new plastic parts and..blabla.. :P i am stuck with antirollbar.
