Mugen MTX-3
Old 05-25-2004, 05:12 PM
  #12361
Bivens's Avatar
Make sure you're not mistaking belt-drag with the brake-pad problem.....check for brake drag with no-belts around the main shaft pulleys....
It's not too difficult...use coarseer sandpaper laid on ahard surface and move the pad across it to get it flat when you get finished dremel-ing...
Bivens is offline
Old 05-25-2004, 05:16 PM
  #12362
gentleman81's Avatar
well i was listening to the pads rub and i ended up destroying one pad, i'll probably just get the teflon ones.
gentleman81 is offline
Old 05-25-2004, 05:28 PM
  #12363
guys,
the prospec does not come with any special main shaft correct?
in other words its not light weight or anything correct?
thanks
Profoxcg is offline
Old 05-25-2004, 05:56 PM
  #12364
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
does prospec come with 3rd front body post
rcpaintinpete is offline
Old 05-25-2004, 05:59 PM
  #12365
chippy's Avatar
Default Re brakes
You should also check that the metal that you are sticking the brake pads to are flat mine where not as they are only punched out in the first place.
Put them in a vice and make sure thet are flat then glue on the brake pads and put them back in the vise and tighten while the glue dries. Then sanding is minor.
But scince have gone to teflon brake pads and the 1 piece brake disc off the mrx3 .
It is the way to go
chippy is offline
Old 05-25-2004, 06:14 PM
  #12366
thanks chippy, any one else do you know how the front sway bar is supposed to be adjusted, it feels like mine is keeping the suspension really tight int the front, its very stiff, the rear is nice and free?
Old 05-25-2004, 06:23 PM
  #12367
nope
Profoxcg is offline
Old 05-25-2004, 07:17 PM
  #12368
chippy's Avatar
Slide the sway bar right out to the stops in the plastic holders
Make sure ithe bars are not touching end to end inside the ball and cup.
chippy is offline
Old 05-25-2004, 07:22 PM
  #12369
No, I don't believe the main lay shaft is titanium. Not a big deal when start comparing the weight of the shaft compared to the brake disk that came with the prospec.
My binding problem solved itself. It was binding this morning but when I showed it to my friend, it was no longer there.
Any opinions what shock pistons to use? I have the stock ones, 1.2, and 1.3 pistons on hand. I'm running on a parking lot track. I was considering 1.2 all around.
darkangel is offline
Old 05-25-2004, 07:27 PM
  #12370
I am so amazed by how easy to build is the MTX3 compared to other kits I have built !!
Profoxcg is offline
Old 05-25-2004, 07:41 PM
  #12371
ditto that
Old 05-25-2004, 08:36 PM
  #12372
Suspended
hudy's Avatar
Profoxcg can you post pics of your prospec if you dont mind
hudy is offline
Old 05-25-2004, 08:48 PM
  #12373
I only have the suspension arms built today. Tomorrow ill try to build some more and take some pics,
Profoxcg is offline
Old 05-25-2004, 08:50 PM
  #12374
Suspended
hudy's Avatar
cool man thx what color is the new chasis black dark green
hudy is offline
Old 05-25-2004, 10:23 PM
  #12375
Ed Delgado's Avatar
Default Here's some pics of my MTX3
Been away for a while, here's some pics.
Ed Delgado is offline
