Mugen MTX-3
#4861
Re: rc world(hong kong)
Originally posted by rcdubs
thanks manticore for that prompt response,quick question any body has any feed back from rcmodel.com in hong kong ,i placed an order and it's taking forever to shipp my stuff(i guess i alrady know that answer "you shoul'd go with Harmony"" ,ok guys thanks for the info,im curious what are you guys ages (just want to know if im the only old fart here
why you ask while you have both the answers?? you are too smart !
#4862
#4863
hi manti i was being sarcastic,im from sunny....well cloudy and rainy california
#4864
It was in October.
#4865
Originally posted by RClover
my new head on the Rody..
when tightened, no issue actually..
#4866
[i]
Dirtly little trick: If you have access to a milling shop, ask for them to deck the internal side of the head to promote better contact with head and button. [/B]
This head makes my engines run 15-20 *F cooloer than a regular NR head.
I'm already looking for a machinist who can turn my 3 ZAC heads...
#4868
Originally posted by stefan
There is a machined head (z-speed) that has the same dimensions as a regular Nova Rossi head, but since the head is machined and not cast, it has an absolutely flat mating area for the head button.
#4869
Originally posted by kilokhan
I got that head works pretty well too...
Anybody tried nova 11 layer head ?
Works much better than the old '9 fins'. Use routinely on my engines because lowers the temp of the engine about 15ºC, main problem with this head is when used with Lola shells is quite exposed to scratches if you flip the car.
#4870
Square HEAD
Here's what I've got on mine.
#4871
Eddie,
I got my stuff yesterday, thanks a bunch
#4872
Eddie,
Eddie,
#4873
Question re Spring
Hello,
I'm now using the FiveStars BLUE spring. When compare to the Mugen's Blue, I've noticed that the FiveStars has less coils. They both have almost the same thichness at 1.74mm in diameter and of course the same in height.
What would the less coils spring perform when compare to the Mugen's one? Any better or worse?
Thank you,
Thank you,
#4874
Generally, making a spring shorter will stiffen the spring.
Easiest example i can think of.. on full size race cars, If you start with a 650 spring, and you cut off one coil, it will end up being about a 750. When you make the spring shorter, it takes more to compress it an inch than it would with the longer spring.
#4875
There is no altered on the spring in any ways. I would just like to know the differences among the two spring brand, see attached pictures--left is FiveStars, the other is Mugen. They are the same in length/height, have the same thickness. The only difference is the number of coils. Please advise.
Regards,
eddie
