Mugen MTX-3
Re: Re: Re: Weight
Originally posted by Ah10
Well said, and stay away from the handle bar by 3racing, it will damage your radio plate!
I saw a killer lil' tool this past weekend. It was a blade swaybar adjuster like the one previously posted, but this was just a piece of stamped metal tool with a fork-like end and a handle, it fit inside the opening at the front of the chassis, where the access to the servo saver is, on any car. He said he thought he got it from "Mico", who, by the way makes the MUST have carbide bit for your tire truer.
I got one for my Ofna tire truer (which is as good if not the same as the Hudy) at WinterNats, any of you FLA guys know how to get in touch with him? It cuts a tire like it came from the box, new.
Re: Re: Re: Re: Weight
Originally posted by drfritz
how does it damage the radio plate?
Front-Sway-Bar Adjustment Tool
Stefan...
I think this is the tool you describe.......Product description says it's made by Mico......
You can find it here....
http://www.ashfordhobby.com/prod321.htm
Re: Re: Re: Re: Re: Weight
Because the 3racing one mounting stud is so small, around 3cm in diameter attach onto the radio plate so when you lift the car with the handle bar it puts a lot of stress on it and if you run lola body and when you fliped then you will understand what I mean!
Re: Re: Re: Re: Re: Re: Weight
yeah, then damage the chassis, instead of the upperdeck?
Originally posted by mckrooz
This is the reason I purchased the bar made by Shooter. It goes through the deck and mounts to the radio supports underneath.
Re: Weight
Originally posted by Bandeira
Seen you guys commenting about weight...
You guys know if the 3racing hopups are heavy?
because I have everything to get my car lighter, such as titanium screws, hinges pins, pillow balls, everything, but stil on 1790...
...cheers...
...cheers...
The 3r stuff is a bit sus, the blade rear sway bar wears quickly, the side brace with belt tensioner breaks, if you want candy get Kawahara or Mugen. You need reliability.
Re: Front-Sway-Bar Adjustment Tool
Originally posted by Bivens
Stefan...
Stefan...
What are hardcore!!
Shooter Roll Bar
User your imagination.
MTX3 Question
Hi guys,
I have a S710 currently but I think I am going to switch to mugen. for one, part are cheaper, the car is stronger from what I hear and it handles better than any other car of the box. The clutch is very responsive (I drove one).
I had a few questoins however that maybe you guys can answer to persuade me to make the move. if I buy a mugen it will be the Pro spec.
1)I want to know how easy is this car to setup, I know the only roll centers you can change is the rear, how easy is it? is this something you can do along side track? is this adjustment so powerful that mugen did not consider making the front roll center adjustable as in the serpent?
2) does the car come with a one way or diff is / there options?
3) is there a way to install a solid axle in the front and or the rear?
4)re: bearings , does the car come with good sealed bearing that I can relube and clean?
5) is the optional pulleys to play with the internal drive ratio?
6) optional parts availability ? aftermarker and original?
thank you guy!
I know this is a lot to ask,
thank you guy!
Re: Shooter Roll Bar
Re: Re: Re: Weight
I saw somewhere in this forum that the MTX3 is for beginners? Just because of easy to drive? And how would a 710 racer would switch to MTX3? 710 is supposed for expert I guess.
