Mugen MTX-3
Old 07-31-2003, 01:56 AM
  #6826
Corse-R's Avatar
Default Re: tires choice
Originally posted by B
what hardness foam tires are people using when they have the 16/19T conversion?
but i heard that when using the conversion, the rear tire's diameter has to be 3 mm bigger than the front
so can this tire combination work? because if the rear is softer, would it wear faster and can no longer be used due to the 16/19T conversion?
Uhm. Tyre hardness shouldn't be mandated by the type of pulleys/belts you've installed on your car, should be mandated by your track conditions and your particular setup.
Yep, front tyres should be 3mm smaller diameter than the rears, many here (Manti, Stefan and others) found that 3mm is the way to go with this alternate set of pulleys.
Regarding running softer rears, cannot tell you anything, still on mine car haven't used a softer rear than a front. Found it that I'm using 40's or harders everyday (doesn't matter if is Summer, Spring or Winter).
16/19 pulleys make their work because rear tyres have more meat thus having more tyre to wear, your rear end will go down at almost (or at the same) pace that fronts. Car handling changes a little (to better for everyone that tested it).
Corse-R is offline
Old 07-31-2003, 03:42 AM
  #6827
stefan's Avatar
Corse is absolutely correct.
I'm not exactly sure why, but since I converted to 16/19, my tires wear at the same rate or at least almost.
Chuck, I run 42/42, but I use Speedmind tires.
stefan is offline
Old 07-31-2003, 05:48 AM
  #6828
alvinm's Avatar
Say you run on an unprepared track with little grip causing you to run softer rears(40 fr-35 rr)Using the 16/19 setup is tire wear still fairly equal?Also are these pulleys mugen or aftermarket?
alvinm is offline
Old 07-31-2003, 07:26 AM
  #6829
stefan's Avatar
Alvin, I am not a believer in different shore ratings front and rear and so far I have very rarely come upon a situation where I could not hook the car up with suspension changes.
the thing is, that even if you run same shore front and rear, the front tires will wear less than the rear, due to their different rubber content.
If you run 40/35,this will be heavily emphasized.
Try to work with setup, rather tan tire compounds.
It will keep your tire stock smaller as well.
The pulleys are stock Mugen pulleys, actually you only need another 16 tooth pulley, but the pulley set is inexpensive and you'll have some spare parts.
stefan is offline
Old 07-31-2003, 07:37 AM
  #6830
eddiethefish's Avatar
damn! Just like what MY FRIEND kept yelling at me all the time!
eddiethefish is offline
Old 07-31-2003, 09:31 AM
  #6831
vones's Avatar
Default 0.8 module recommendations
Hi guys, I was wondering if anyone can advice me on the 0.8 module........currently I'm using the 1.0 module...17/48 with 21/44 for a coming race...can I use the same gear ratio as offered by the 0.8 module or do I hve to increase my gear ratio? I understand that the 0.8 gear offers a better top end speed....thks
File Type: pdf
vones is offline
Old 07-31-2003, 09:47 AM
  #6832
Default Re: 0.8 module recommendations
IMO, keep it close to what you have is a pretty good starting point.
Old 07-31-2003, 10:20 AM
  #6833
Corse-R's Avatar
For the gearing you're using, you will be fine with almost the same combo I'm using 21/59 & 26/54 (I use 21/58 & 26/53).
This one I said is slightly longer on 1st gear (7,132 vs 7,097) and the same on 2nd gear (5,293 vs 5,246). Differences shouldn't be noticeable.
A slightly shorter and slightly more closed gearing (good for mid to high and strong 2nd gear shift) could be 21/59 with 25/52 and let your engine whine at the top end.
Corse-R is offline
Old 07-31-2003, 10:44 AM
  #6834
alvinm's Avatar
I try to keep shores simular but with the track being so dusty its hard and most drivers there do too.When its overcast or late afternoon the rear shores go up.Regarding the 16t pulley,you will also need a bigger belt correct?
alvinm is offline
Old 07-31-2003, 10:48 AM
  #6835
stefan's Avatar
stefan is offline
Old 07-31-2003, 10:49 AM
  #6836
stefan's Avatar
Alvin, the original pulleys are bigger (19/24) and therefore you'll need a smaller belt.
stefan is offline
Old 07-31-2003, 11:17 AM
  #6837
alvinm's Avatar
Cool,they have the specific belt available?.Aside from the tire wear is there any differences in handling(more or less steering etc...)Thanks.
alvinm is offline
Old 07-31-2003, 11:21 AM
  #6838
Corse-R's Avatar
PM me if you're interested in the shorter belt, monday or tuesday will get more available.
Corse-R is offline
Old 07-31-2003, 07:09 PM
  #6839
vones's Avatar
Default Re: Re: 0.8 module recommendations
will do...thks eddie
vones is offline
Old 07-31-2003, 07:16 PM
  #6840
vones's Avatar
ok, I understand what u mean....thks...
vones is offline
