Mugen MTX-3
#3556
Originally posted by puma1824
3. What would be the best long term solution (keep long term cost and durability in mind) Universals (which brand) or MTX2 dogbones, Stock dogbones w/proper length fuel tubing (what does that mean? - please explaing)?
-Puma
-Puma
I solved this by using a length of fuel tubing(a spring would do too) inside the diff outdrive to keep the other end inside the drive cup. Reducing the steering throw and tightening the servo saver also prevents them from falling out.
#3557
alloy engine brace
Can someone post the part number and vendor for the engine brace? Actually just the vendor will do. Is it a Kawahara hop up?
Thanks,
Kevin
Thanks,
Kevin
#3558
kfactory makes clutch bell gears up to 23 tooth
i know what hes talking about that track over here in ohio is huge and the mtx2 (which has the same overall internal ratio) was under geared for it
the trinity team had a 23 tooth and they were fine mugen only had a 22 and they were getting killed on the straight thats why mugen did so poorly at nats and worlds
i didnt have even a 22 to run it was horrible i would reach my top speed only 1/3 of the way down the straight
i hope that they even make a 24 tooth in case i go back to that track it was huge
#3559
the cheapest and easiest solution IMO is the mtx2 dogbones paint them or polish them so you can find them if they ever come out but i am almost positve they will never break
on my car i have put the bones from a mtx2 universal onto the outer portion of a mtx3 universal i broke
#3560
First peek at Kawahara Rear Sway Bar.
wonder if Manticore gets one yet...
#3561
And, here's the Kawahara MTX-3 Chassis
Enjoy all!
Enjoy all!
#3562
#3563
Originally posted by Corse-R
Don't doubt for less than 1/1000th of a second, he's the hop-up man.... er.... the hop-up king.
#3564
Originally posted by Manticore
bow bow !! but i havent got that yet !!
Comment anyone?
#3565
Any comparison between Kawahara's and other hopup brands re this sway bar?
Comment anyone?
Comment anyone?
1/. kawahara, the best design which works with any rear bulk head cross member
2/. 3racing, the worst one which required its own rear bulkhead cross member and sway bar set and there is some slop on the joint.
3/. Charge, another japanese option house. it also works on any cross member but it doesnt work on blade, you adjust the distance of the ball/cap to adjust sway stiffness.
#3566
right now there are only 3 brands release this option.
Team Charge's Harden Pinions: 15T, 16T, 17T and 19T, 20T, 21T.
Still doubt about the quality on K-Factory's pinion as I've seen one and it looks funny. The coating was cracked and looks like a "paint crack", too.
#3567
I'll bring some Harden Pinions from Team Charge as Racing Jack has been so slow producing the goodies I need.
kfactory is not on my list. GPM is there because just want to show comparison !!
#3568
#3569
#3570
Re: rody 5 port modified
Originally posted by rcdubs
hello what pipe should i use on this engine ,rb,nova??????,also do you guys think is worth having these engine modified even more,may be a murman or smeltz rody modified?????? im new at these so for sure im going to blow these engine up
my friend blew up his Rody 5 Port with only less than 2 months old..!!!
