Mugen MTX-3
Originally Posted by asw7576
Hi Slot, softer setup of yours means softer springs or softer boil weight ? Or perhaps softer springs with slightly thicker oil ?
what other companies make a low friction belt for the MTX3?
http://www.robotcombat.com/store_timingbelts.html
Anybody have any experience with the kawahara neg diff? Iv'e got a used pro spec with one in it, but with no instruction manual. Any help would be great! Thank's.
can you even tell a difference with the low friction belts??
thanks
Mike
thanks
Mike
Im not sure if u can tell the difference, i just want somethnig that doesnt start to come apart after 2 runs. I have has a couple of the mugen ones start to come apart after a couple of runs. Its like the side of the belt delaminates and just peels up from the rest of the belt. Any ideas on an easy fix.
What upgrades do you think are necesary for the MTX-3. Simple things that you can do to the car to make it better. I have one, and I like it as it is, I have it stock, I havent' done much to it. But i'm willing to start putting some money in it. If you could please help me..
Thanks,
Juan
Thanks,
Juan
Thanks,
Juan
Thanks,
Juan
The car is a performer right out of the box.
IMO the best thing you can do is upgrade your engine or servos.
is it worth changing sum plastic parts to carbon fiber......and the stock prospec doesnt come with the 0.08 fine pitch gears????
one question...what spares would you need for this kit.....i will slowly get sum stuff over the winter time(canada) preparing for next season
thanks
Mike
thanks
Mike
thanks
Mike
thanks
Mike
I think the plastic part is strong enough so basically the car is good enough out of the box.
The only few things needed is front universal and probably you can try titanium middle shaft but all is inside prospec kit.
The prospec come with 0.8 module.
The spares you need probably is rear bulk head, front hubs and belts
That's my 2 cents
from stock...
go titanium pivot balls.
light weight mid and front shafts.
mugen cvd's all the way around.
aluminum engine brace.
and if you got some dough left... titanium screws.
NOW...IS THAT FROM STOCK FROM THE MTX-3 PROSPEC OR JUST THE MTX-3???CUZ IF IM NOT MISTAKEN..DOESNT THE MTX-3 PROSPEC COME WITH THE TITANIUM PIVOT BALLS?
THANKS
mIKE
THANKS
mIKE
THANKS
mIKE
THANKS
mIKE
The prospec does come with titanium pivot balls. The normal Mtx 3 has steel pivot balls.
MTX3 prospec comes with titanium pivot balls & middle shaft already. So if you want lighter weight, get titanium screws & titanium 2 speed shaft.
