Mugen MTX-4
#7937
Hope that the new Rigid/one way is soon available.
#7938
Just wondering what you guys with the mtx4 are using to turn on and off your electronics?
Have just finished building the kit (awesome car) and electronics are in, I ended up mounting a spare futaba switch onto the optional switch mount which goes beside the transponder holder, the size of the switch makes it look nasty and actually binds with the break linkage a bit..so looking to create/purchase a alternative.
I was thinking of doing something like the g4s has with the futaba female and male connectors and just do a direct connection rather than a switch but any suggestions or images of what others are doing be great, thanks
#7939
Setting up the power as a direct connection with a short extension lead is the best way to eliminate the problems associated with running a switch, not to mention that there is less wires running around the place!
You can also get yourself a set of mini Deans plugs to use as your conection on the battery lead and extension lead.
I have seen them used on several cars with great success.
#7940
I dont use a switch, I just plug and unplug the battery from the RX
#7941
i am using airtronics/sanwa switch which has 2 sockets. one is connected to the battery jack forever and ther other is particularly for connecting to charger plug. it never fails.
i had the problem using the extension cables by KO before, loosing control , because of the extension plug(KO type) was loosen and loosen as the car sometimes drove over the bump, finally loose control, the front end of the car was totally destroyed.
But using that sanwa's stuff, i have no problem.
#7943
Originally Posted by itchy b
Here's the pic for you Kosta, of the item i mentioned earlier
And yes, it's been a while since she's had a thorough clean!
#7944
Location: Time to put down the Golf clubs and poker chips and GO RACIN!
Does anyone run the lightweight clutch parts? flywheel ect..
#7945
#7946
Originally Posted by dg8one
of course man i told you that sunday
V said it was not worth it..
#7948
Originally Posted by Car Breaker
This is what I did, I stop using switch on touring car after I bought my 710, either servo plug or Dean's Micro plug. I have plenty of the unassamble servo plug at home to make these and to shorten my servo wire as well
My tips : I'm using thicker cable for the servo cable extension...... to power two 13kg digital servos. Thinner cable might burn out to carry heavy loads.
#7949
K factory main shaft
Mugen titanium mid shaft
drill out the stock or buy the MSR hubs
Aluminum pinions are debated on here all the time ( I don't know the best answer on this one) I run aluminum.
Rubber belts for racing, Urethane for club events and practice.
Skyline first gear hub (Kawahara)
Skyline second gear hub (Kawahara)
I have a 3 racing lightened clutch bell, but I feel like it eats clutch bearings. So I don't use it.
#7950
Thanks Man.
