V-ONE S Thread
#3346
Originally posted by sausage_link
by changing what??
you need to give more information... dont just expect people to complete what it says there coz u cant be bothered typing the rest out
but yeh adjusting the shocks should change the ride hieght i think
by changing what??
Spacers could have that effect if the droop is too restricted, try backing off the droop screws and see what happens
gt
#3347
i never liked the standard shocks on the S so i upgraded them to V-one R shocks. Alot better quality, aluminum build, threaded body so adjustmens are more acurate and they dont leak.
springs set the ride height of the car so the more compressed it is the heigher it is, the less pressure or compression it has the lower it is.
#3348
Originally posted by squizzytaylor
Far out, be nice to people Saus!
i just dont like it when people ask for help and dont give u the required infomation and expect u to work out the rest.
no hard feelings
#3349
johan798:
What id say the problem is, is that your droop screws are limiting the downtravel of the suspension arm, which in turn, limits the shock movement, check that they havnt been screwed in too far, and if so, try using a droop gauge.
#3350
I recieved my stuff today. Got my Mini-Z, setup station, tyres and lots more.
I'm a very happy boy !
#3351
hows the setup station?
#3352
It isnt the screws I have them in default position.
Can someone give me an explanation how it should work(adjusting the ride height by changing collars).
#3353
basicly adding shock collars should raise the car because it makes the suspension have less travel so the suspension lifts the car higher.
are you trying to go lower or higher?
hope this helps
hope this helps
#3354
I am trying to get it to work at all.
Can the spring be to big????????
#3355
1) Is the shock mounted in the correct hole?(upper or lower)
2)do you have the right size lower shock ends fitted? (there are long and short)
3) have you tried it with no spacers? if so what effect did it have?
4) have you tried removing the droop screws alltogether (1mm of adjustment at the screw end = about 10mm an the hub.
Go back to basics! every one buggers up something, be it large or small when assembling a kit.
Do you have a digital camera? if so take a photo of the shocks as they are assembled on the car and either post it here or email me at [email protected] and I shall endeavour to help!
gt
#3356
info
Hi need info on the gearing for the two speed. i am having a sirio 5 port and i am running 18/19 pinion and 40/43.
what size gear should i change to have more overall performance? i had tried 39 already.
thanks in advance
thanks in advance
#3357
Re: info
thanks in advance
thanks in advance
For example
16/48 = 64
20/44 = 64
17/49 = 66
21/45 = 66
If you dont follow this rule your going to be stripping gears left right and centre!
From memory your 2-speed instructions should have the gear ratios.
gt
#3358
Okey
I have a digital camera not good(its a webcam)I will try everything you have wrote and send some picture.
Thanks.
Thanks.
#3359
Here are the pictures squizzytaylor.
The springs should not get stiffer when you increase the ride height, right????
#3360
cant post it to big mail you
