Serpent Cobra GT
#2596
#2597
Finally today I got a 3.0 2 speed (car was 2.0 modded to 3.0 except the 2 speed.
In the manual it looks like the 2 speed shoes are reversed? As in the housing the holes are pointing the wrong way to get wrench in to adjust the two speed?
The old two speed the shoes run the opposite direction.
The set screw in from the inside out went fine. As for the main screws with springs, how far in is 'all the way'?
Do you compress the spring till it can't compress any more? I found it hard to feel what all the way was while screwing and was scared of stripping it, so stopped. Thought I'd ask on here first!
#2598
Is this right?
#2599
That looks fine. For the 2speed functionality the direction of the shoes does not matter.
For the setting screw in till the spring is compressed then out the amount stated in the manual. In any case try to get both screws the same. You can pull the shoes apart by hand and see if the the gap is the same on both sides.
#2600
#2601
When you screw the grub screws in from the inside make sure you don't screw them all the way out and leave at least 0.5 - 1mm of the bore bare ie with no thread cut. This is to stop the grub screws backing out in use.
The adjustment screws should be turned in all the way until you can feel the spring fully compressed and then back it out initially 3.5 - 4 turns. I know the manual states 3 turns but in my experience of this gearbox in the GT car the standard setting is a bit late, especially if you are also breaking in a new engine. You won't strip it and you will feel the spring full compress. Don't over tighten and squash/deform the spring.
#2603
#2605
#2606
#2607
What brake plate mount screws / tubes do you use for srx8 pro brakes? Standard doesn't fit well. Screws in way too far or is too loose if not screwed all the way in.
#2608
I mean the standard 3.0 kit screws/tubes the tubes are too short. Does 3.1 come with longer tubes? Or do you use something else?
#2609
When I fitted the SRX8 brakes on my 3.0 car I just fitted the discs and carried on using the pads from the GT Pro brake kit which is now discontinued because the srx8 pads were too thick and didn’t fit properly.
On the 3.1 kit there are revised fittings. So to fit both the srx8 discs and pads You need the GT 3.1 plate mounting kit.
It’s brake plate mount set GT 3.1 part number 600988. http://www.serpent.com/product/600988
#2610
For reference for those guys making the switch from 3.0 to 3.1 this document might be useful for you....
http://www.serpent.com/file.php?FileID=6960
