Serpent Cobra GT
#1831
#1832
The 600286 is discontinued. 600706 is the same but it has a little more room(side to side) for the center shaft because the new SL8 2 speed is a little wider (about 2 mm total aprox). In your case, with a couple of shims to space out the flange bearings, you should be able to use it without any problem.
Glad you are using the car in a different application. Will be cool to see some pics..
Here also is the video of the A main, I was on the pole
https://m.youtube.com/watch?feature=...&v=dOFerUtG2wY
Thanks for the responses
#1833
Engines and pipe
What engine and pipe do you guys use on your GT? What seems to be the most popular choice? My club has an open rules regarding engine, as long as it is .21 size (not limited to 5 ports 7mm insert rules yet).
#1834
Here is some pics now that it was back together and run last weekend. Just added some shims and the new version mount worked perfect.
#1836
Good job in Miami, wish I could've been there
#1838
Hi Guys, how can I make the RTR car clutch more punchier? many thanks
#1840
Does anyone tried the FRONT roll center diff case kits for the 3.0? I know Paolo used the rear one, but they just released the front raiser kit....don't know what that will do.
Also, I just realized that the 3.0, the center drive shaft are now using dog bone (back to the early version of the Cobra 811) instead of the CVD type....why the changes? Easy removal of the 2-speed?
#1841
#1844
The spacer is rising the centre of gravity not roll centre, hence the roll arm increase so more roll.
#1845
The XLI gearbox mount is narrow than 2.0, but the length of 2 speed shaft is longer
