Serpent Cobra GT
#1621
#1622
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
those chubs really wake the car up and slightly better tire wear too.
#1623
Also, I found the problem finally. I'm using on road engine, the default gear ratio is to fast and no engine brake. I will try to lower the gear to 15T/18T. Thx guys
#1625
My friend use the GT engine in 16/19T in same setup, he can keep on throttle
corner by corner.
#1626
Hi, could anyone measure the diameter and length of a Cobra GT shock shaft?
#1627
Not really this reason. F. diff too lose will lost control. I've found its gearing problem.
#1629
Anyone running Buku Speed Tune clutch with Nova GT engine? whats the spring tension setup? I've there's alot wheel spin.
#1630
IF all springs have same tension on top of being set tight, the clutch should engage very suddenly. For a smoother engagement, you could try setting each spring with a different tension. For example you could try 1.5, 2.5, 3.5 turns from your 0 point...
To set your 0 point, try unscrewing/screwing your set screws until the spring just starts touching the flywheel (you have to do this with clutch off so you can see the back of flywheel).
#1631
Hi!The tension is up to you, depending how you want it to feel... If it feels too punchy like On-Off kinda feel, you could check if you have a lot of tension but you might also have no split in tension between the 3 springs.
#1635
