Serpent Cobra GT
#1471
Parts to get
600136 10 deg C hub plastic
LOSA3545 Losi 2.0 Brake Disc
#1472
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
Those are two cheap and great bang for the buck parts recommendations right there.
#1474
Hi guys,
Here are a few videos of practice at Floyd today. Andy came by, and Joe let me drive his car :-)
Thanks Joe!
https://www.youtube.com/watch?v=342wq6Ydkko
https://www.youtube.com/watch?v=JcGv_NTzJrI
https://www.youtube.com/watch?v=t0Lmgb9jlCw
Thanks Joe!
#1475
Out of the box it greatly depends on how crazy you want to go. My self I grab everything but that's because I like shiny things. My advice would be to grab the plastic 10 deg chubs and a set of Losi 2.0 brakes (Ill post part numbers below). Take the car out from there and see where you want to go with it. The car can be set up in so many different ways and upgrades will only fine tune the car to the driver. Once you figure out where you want to go we can point you in that direction. If you want a full out build like I do I can list those parts as well just let me know.
Parts to get
Parts to get
tnx
#1476
Hi guys,
Thanks Joe!
Thanks Joe!
#1477
Great li'l circuit you guys have there! We use the local basketball court but the surface just isn't smooth enough to give good traction.
#1480
Manual or tutorial for C hubs and steering blocks
Is there any manual or tutorial for installing C hubs and steering blocks. I got the 0 degrees (600694 + 600611) but they look different from the stock ones. I 'm a bit confused. 1. How to remove the driveshaft? 2. Why don't the steering blocks have those attachments on top and bottom? The stock ones seem a lot bigger. 3. Do you need to remove the battery/receiver box to install the servo lever steering?
#1481
Hi guys,
Thanks Joe!
Thanks Joe!
#1482
Is there any manual or tutorial for installing C hubs and steering blocks. I got the 0 degrees (600694 + 600611) but they look different from the stock ones. I 'm a bit confused. Guessing you're working with a RTR car - see the Serpent site to download the instruction manual1. How to remove the driveshaft? - there is a set screw in the center of the axle , loosen that and the pin that drives the hex hub slides out.
2. Why don't the steering blocks have those attachments on top and bottom? The stock ones seem a lot bigger. - the aluminum parts are minimized to save weight , they work fine. 3. Do you need to remove the battery/receiver box to install the servo lever steering?
#1483
Installation finished, but how to lubricate?
@ Rick Davis
Yes, it's the RTR. I installed them now, thank god there was a little setup manual included with the car that gave me some hints. Nevertheless it took me 3 1/2 hours. And the tuning parts themselves should have a little manual too because they are different from the stock ones. Very confusing.
The only thing that disappoints me is that the steering blocks don't have these little holes to grease the bearings... Any hint on this?
#1484
Hello I currently have a kyosho inferno gt2 right now going to run this summer but it's tired. I want to make the switch to a serpent. I kind of need to know is it better to get the ready to run or the sedan kit. And Does the kit have the upgrades? Please steering me in the right direction.
#1485
