Serpent Cobra GT
#1651
Ok Dan well I will be waiting on that Gt been wanting one since 2014 but like I said when ok saw the release date of the Gt I was like there has to be a new one coming out so I been waiting. But like you saiid heard the same thing how great the car was an they don't see a new one coming out at that time bc of how well the car performs. So I Just wanted. to. Be up to date when I invested in the Gt platform but thanks.
#1652
Me too. Looks good. Some of the items are in stock at Desoto already! P/N's are basically 600699 onwards. So search 600699, 600700, 600701 etc....
As I've seen the changes are:
SLi8 Gearbox from 977evo
Front and rear centre driveshafts changed to dogbones (no longer CVDs)
Front and Rear new shock towers
Front lower arm pin alu suspension mounts new
6 degree alu C hub as standard (standard plastic steering blocks)
New alu gearbox centre holders (standard fibreglass brake disks)
Front and Rear lower shock mount extensions (shocks mounted more outside)
There might be more but thats what I can see now. All the plastics, diffs, axles, driveshafts etc remain the same as the current version.
#1653
I can't wait to try the new parts
#1654
The King Cobra edition (that's just what I call it) with all the upgrades and options will be made "hopefully" but a date is not set yet.
But there's no reason to wait fellas upgrade your current Cobra platform and enjoy the benefits of the newparts now. They truly work and give you a wide range of setup options for your personal driving style.
Serpent quality and support is First Class!
#1656
I live less than 45 minutes away from Desoto racing and I'll be the first at their door once it's released.
#1658
The current 2sp jumps around between 1st and 2nd sometimes in sweeper style corners and it doesn't stay in 2nd when it should do which is the same issue we had with the 977 gearbox. The evo gearbox is so much better and will be on the GT. I think we will also see certain current required upgrades standard in the kit including the 0 degree caster blocks and centre diff brackets in Alu. I don't think you'll see pro brakes as standard though. Think what they did with the cobra buggy that ended up having the Alu 14 degree caster blocks as standard etc...
The new pitch gears and smaller 2 speed give better acceleration I heard. I haven't tried them so I don't know.
#1659
HI Dan, I think that the reason why the 2 speed can jump from 2 to 1 is because the set screws in the center are either not there, not set properly or simply backing out... There is nothing wrong with the SL8 gearbox, I mean not that I know of.
#1660
When will the Cobra GT 2.0 (king cobra) be out ?
Wanting to get a new car but will be waiting for this then
#1661
It's is the GT 3.0 the current car is already 2.0! It will be out within a couple weeks. The parts to upgrade an existing car are already available at Serpent America.
#1662
The new shock tower and mount are good, I can use softer spring for more grip.
#1664
Nice.....what is the improvement/advantage of each of these new parts over the previous?
#1665
