Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 01-20-2005, 03:16 PM
  #1141
3racing driveshafts seem ok, used a set in my g4 for a year with no problems, have now put a set on my rrr.
some of there alloy products leave alittle tobe desired, alittle weak and bend quite easy, but driveshafts ok
jas1 is offline
Old 01-20-2005, 03:21 PM
  #1142
By the way, what does SSG stand for?
SpeedsterRRR is offline
Old 01-20-2005, 03:26 PM
  #1143
Ron C.'s Avatar
Hi SpeedsterRRR,
SSG means Silver Surface Graphite.
Ron C. is offline
Old 01-20-2005, 04:15 PM
  #1144
fastrcracer's Avatar
Default World'd Edition
Where can I find one of the world'd edition cars ?
fastrcracer is offline
Old 01-20-2005, 06:09 PM
  #1145
NiMo,
i sent you a pm.
Joe Chaplow is offline
Old 01-21-2005, 06:34 AM
  #1146
NiMo's Avatar
Default Re: World'd Edition
You won't, there are not yet released
NiMo is offline
Old 01-21-2005, 07:23 AM
  #1147
NiMo's Avatar
Due some time in March, a Pull-Start sports version of the RRR, called the V-one SIII.
NiMo is offline
Old 01-21-2005, 09:07 AM
  #1148
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
how do you know so much!
Marcos.J is offline
Old 01-21-2005, 09:21 AM
  #1149
NiMo's Avatar
I check through the Japanese sites, then use the translator
NiMo is offline
Old 01-21-2005, 09:38 AM
  #1150
Super Moderator
Marcos.J's Avatar
cool , Nimo does the rr conversion come with a set up?
Marcos.J is offline
Old 01-21-2005, 09:54 AM
  #1151
i have an extra rrr. i used it for spare parts. when i used parts, i ordered new ones and replaced. i am selling this kit. all parts are there. i will take $250 for it. my email is [email protected] or 305-807-9529.
Old 01-21-2005, 10:13 AM
  #1152
NiMo's Avatar
Comes with a set up sheet and a new blank set up sheet.
I haven't been able to get the best from the RR yet, trying a front spool was not a good idea and set me back a bit.
NiMo is offline
Old 01-21-2005, 10:23 AM
  #1153
Super Moderator
Marcos.J's Avatar
thanks
Marcos.J is offline
Old 01-22-2005, 07:35 PM
  #1154
Racing4Evo's Avatar
I got the new Skyline Racing exhaust mount a few days ago. It is the best designed alternative to the stock method of securing the exhaust wire. The way Kyosho did it at the Worlds and how I use to do it was mount an standard aluminum holder to the upper plate. In a severe crash, the upper plate can fracture from the shock of the impact. The Skyline mount uses the existing hole in the upper plate but also rests against the upper part of the front bulkhead for added reinforcement. It comes with a screw to attach the mount and a setscrew for the exhaust wire. Not to mention the anodizing matches the factory blue to the "T"!
Racing4Evo is offline
Old 01-22-2005, 08:31 PM
  #1155
TRAJ's Avatar
Hi
where can we get these from?
TRAJ is offline
