Kyosho v-one rrr
#8071
Originally Posted by Kyosho3PKRacer
I remember having this problem ages ago, i think you move the 2speed cam closer to the bulkhead. Try that see if it fixes it, i'm sure someone knows definately if thats the problem or not and will post soon.
#8072
you are absolutley correct.....you need to readjust the 2speed cam.....until you find the gears spin freely in both directions......
#8073
hmm
unfortunately i just had this problem at the KYOSHO RACE i stripped 3 2nd gear spurs
#8074
Originally Posted by Black_Widow
You mean moving parts no.149 to no.158?
#8075
hmm
good info very good
#8076
if adjusting the cam is not enough, try put a thin washer behind 158. the O.D. of the washer need to be smaller than the O.D. of the steel sleeve (157) so it won't interfere with the rotation of the one way bearing. and the thickness of the washer need to be right too so the first gear won't move up and down the shaft too much.
#8077
hmm
also check the bearing make sure its not siezed for the 2speed
#8078
Hi guys,
What u guys suggest is that I realign the red portion? Btw which area is the bulkhead? Actually I'm still confuse between the 2 spur gears. Which is the first gear which is the 2nd gear?
#8080
Hi guys,
Yes that is right, move 2 speed cam further down the shaft, the bulkhead is the plastic bit everything screws into i.e. brake lever,shock tower etc.. and shaft goes through.
undo grub screw on 2 speedcam and move it closer towards car a bit and tighten again, making sure it is still tightening on flat spot of shaft of course.
1st gear is on the outside of car and 2nd is on inside, or 1st being bigger on spurs and 1st being smaller on pinions.
#8081
I recently picked up a barley used V-One RRR from a guy, I have taken it apart to reassemble it according to the instruction manual. I am going to put a diff in the front when I put is back together also. I belive I have all the parts to do it except the the pulley set to change the front drive pulley which is on it's way from Kyosho. My question is will I be able to use the same front belt as before? I did'nt know if it would be the same becase the diff pulley gear is bigger and the drive pulley will be smaller right? Thanks guys
#8082
same belt dude...
also same pulley as whats on the oneway, just without the side clipped onto it, cause it uses the side of the front diff for that.
cheers.
cheers.
#8083
Pivot Balls
Is anybody using titanium pivot balls? If so, what brand and how do you like them?
Thanks,
jag
Thanks,
jag
#8084
HMM
Thanks,
jag
Thanks,
jag
#8085
Originally Posted by SOLOARTIST 702
YOU BEEN RACING I HAVENT SEEN YOU ON HERE FOR A WHILE
