Kyosho v-one rrr
#7982
hmm
Originally Posted by maskedrider
meaning he using back WCE instead of Evo !!
#7983
Originally Posted by robert maestrey
-F/R spring Blacks
-F/R shock oil 600
-Rear diff Oil 30-50000
-Caster stock
-Camber 2.5 front 3.5 rear
-F/R Toe f-1 deg. out r-2 deg. in
-Gearing 1st 16/61 2nd 21/56
-Shock position 1 hole up front 2 hole up rear
Hope thi s helps
Robert Maestrey
-F/R shock oil 600
-Caster stock
Hope thi s helps
Robert Maestrey
right now i'm still having trouble with low speed turn, and don't have much on power steering out of turn...(my car always push entering and out of corner)
#7984
What tyres are you using? Make sure you're using at least a 2mm split front-to-rear.
If you're car is suffering from turn-in understeer either change the spool to a diff with 30,000 or 50,000 oil or even a one-way, as long as you don't have to brake too much.
Set the rear anti-roll bar harder or go to the harder version.
How do you have your front anti-roll bar set?
#7985
MUGEN THE WORLD CHAMP 200MM
#7986
ok thats not called for gess you dont have to rub it in
#7987
can someone send me a link to purchase the servo horn arm-like for Kyosho V-one rrr which is not included in the kit? or other recommended servo horn tat will be useful. Using futaba s9451 servo.
Thank you PPL
Thank you PPL
#7988
Thank you PPL
Thank you PPL
#7989
Adrien Bertin used a RRR WCup with option of Evolution kit but without the carbon radio platine.
#7990
Removing gears from clutch bell
hey all,
i tried to change the gears from the clutch bell, i have the stock one provided with RRR.
but i couldn't loose them, so i stoped the procedure i was afraid to distroy the clutch bell.. do you you any special tool in order to take them out of it?
antony
antony
#7991
Originally Posted by antoine80
hey all,
antony
antony
#7992
get the kyosho pinion removal tools....
http://www.the-border.nl/product.php...cat=294&page=1
Kyosho Kyosho 2-Speed Clutch Tool 0.8M vzw040
#7993
you mean this tool :
#7994
yes..... you are right
#7995
What receiver batt pack r u guys using?
Hi ppl,
Wonder wat are the recommended mAh? 6v flat battery pack and charger to be use for this v-one rrr, i'm using futaba s9451 for both steerin n throttle max require is 4.8 - 6v.
Just curious, wat will the dmg impact for using 7.2v flat battery pack to the above servos?
your comment n advise ppl
thanks
thanks
