Kyosho v-one rrr
#706
Originally posted by joemugen
anyone have an overdrive calculator (spreadsheet)? thanks.
Try this http://www.ziggy12345.plus.com/Cars/V-1-RR%20MPH.xls
Its for the RR but will calculate anything as long as you put in the right tooth numbers
Cheers
#707
ziggy, thanks for the spread sheet. what is everyone doing about covering the receiver up so it does not get gas on it?
#708
Originally posted by rjl
I've been using Zacs for the past year, you're right, they work great. Were you on the ZB or Z rims?
#709
#710
Receiver Cover
Try putting serpent cleaning gum over the wires.
#711
Originally posted by rcosmax
Thanks 3434
Just so i have this correct some of the middle shafts carry over to the rrr but not all? the vzw-025 does not fit? How about gearmain shafts? have they released any lightweight versions? And how about the first gear 1way holder...is there a lighter version of this too?
I ill check all those parts out. the midle shaft doesnt have a ton of stress on it so i think i will try the 3racing. torsional stress but no slamming into the boards stress like a cvd.
Thanks for the help.
Thanks 3434
#712
Front toe.
Maybe I've missed something, but I can't seem to adjust the front toe, whilst the RRR is mounted on the Hudy setup prisms.
I see there is a little hole in both steering rods, but the upper arms prevent access to it
Is there an easy way of doing this?
Cheers, Mark.
Cheers, Mark.
#713
Re: Front toe.
#714
Re: Re: Front toe.
Originally posted by InitialD
I don't know how this is blocked but on the Mugen, they way I see it's done is to use an L type allen into the holes in the steering rods to turn them. Perhaps then it's reacheable.
#715
Re: Re: Front toe.
#716
Finished
Feast your eyes on this, guys! Three days hard work and here are the results:
#717
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
Very nice If it wasn't because the impossibility of getting parts for it in Sweden I would buy one
#718
Re: Finished
I see you're hiding and stuffing old engines and pipe on the RRR ! That's not acceptable ! Nice photo work.
#719
Re: Re: Finished
Nice job Mark !
Nice job Mark !
#720
Re: Re: Re: Finished
Thanks D - if only everything was as good as my photo work
