Kyosho v-one rrr
#7082
Originally Posted by Osiris 75
I'm just guessing no one knows, because I've asked the same question...
I will dig around and se if I can find the part numbers
#7083
The part numbers for the diff assembly are on page 37 of the manual.
Dave
Dave
#7084
Originally Posted by jag
Nice track.
I noticed that you have your car setup soft in the rear. You are running 7000 wt. in the rear with silver springs? Does this help plant the rear of the car? How is the steering with this setup?
Will try some rollcenter adjustments with the front upper A-arms this weekend.
#7086
Originally Posted by litespeed-dom
Thanks Dave. It's actually on pg. 36 in the manual.
VZ218
VZ012
BS107
VZ203
VZ204
About $45 retail to make it happen.
Dom
VZ218
VZ012
BS107
VZ203
VZ204
Dom
#7087
Grinding? I've ran a front diff in my car for several tanks and it fits right in using the 11 saver, it's not loads of room left but it's clear from the servo saver.
#7088
#7090
#7091
I like the car planted in the rear, since i have a quite aggressive driving style (for example, i had about 3mm foam left on my left rear wheel after the main ) The traction was also a bit low so the 7000 wt diff helped the car to feel more planted (got a bit more corner entry steering too because of the loose diff). The steering was dead on, never driven such a fast yet easy to drive car.
This is good info.
My car is setup similar. I was having problems with the car wanting to push abit through the corners. (Very tight track) For this I removed the rear sway bar which increased rear traction, but I will surely try the 7000wt oil and the silver spring.
What about the dia of the tires? What you found to work best for you?
#7092
Originally Posted by V1-RRR-WC
Hi Sparx,
This is good info.
This is good info.
#7093
Originally Posted by need-4-speed
Just a tip: If your car is pushing that means the rear of the car has too much traction. By removing the rear sway bar you have actually made the push even worse. A better approach would be to flatten your front sway bar, then maybe stiffen the rear sway bar to free up the rear and give you more turn in. Another tuning option would be to dial out some rear toe. You can also increase the amount of droop in the rear to increase the response of your car when turning. There are a lot of tuning options to fix a push. Just try them one at a time until you hit the sweet spot. I hope this helps.
Inside joke: I thought the Hokage outlawed Nitro racing in the Village? Have you and Naruto been at it again?
#7094
Guys I am bulding a RRR is not WCE and I noticed a lot of play in the upper suspension arm I tried some shims combination but did not work.
Any sugestion?
Thanksss
Any sugestion?
Thanksss
#7095
Any sugestion?
Thanksss
Any sugestion?
Thanksss
