Kyosho v-one rrr
#3061
What rear diff oil should i use with the one way? Its for a med size track.
Cheers
Cheers
#3062
I like the stock 30,000wt oil in the rear when I`m running the front one way.
#3063
Cheers
Cheers
#3064
What is a good place to buy tires?
#3066
Does anyone know if there are stronger pillow balls than the stock ones? Are the Evola ones the same, as far as size and material?
#3067
Before them I lost a suspension arm nearly every meeting due to the ball snapping off too far inside the suspension arm to recover.
#3068
Originally Posted by jeffreylin
Check out this post. I think it says good overall.
http://www.rctech.net/forum/showthre...07#post1652407
what is the piece that actually creates the 2 degree offset in the rear on the world edition? i.e. what exactly do i need th change to have no offset?
#3069
Originally Posted by NiMo
I put in the Kyosho Titanium ones In my V-one R, then re-used them in my FW05, they have not even bent, best $65 I've ever spent.
#3070
Originally Posted by joemugen
jeffreylin,
This will give the rear drive shafts a 2mm offset so you can run 0mm offset wheels.
I've done it to mine.
#3071
I saw 3Racing makes titanium ones.
#3072
VSW007
#3073
#3074
#3075
In addition to NiMo's suggestion, the black Evolva ones are great too. They are very strong and you will never have to worry about them bending again.
