Kyosho v-one rrr
#2297
I have a yokomo SD SSG(silver) w/ CGM conversion that I would trade for a very good condition RRR. It's currently built as the CGM and is in excellent condition. I've only raced it on carpet. SD kit $300, Conversion ran me $149. If anyone's interested PM me for pics and info. Like I said excellent condition.
#2298
RRR
I have a RRR for sale on ebay. Item # 5972392840. Email me here if you interested. Its one month old.
#2299
If anyone has a Triple R for sale please PM me.
#2300
Where can I find the WC kit standard setup? I lost that setup when I was moving.
Regards,
Arvid
Regards,
Arvid
#2301
Muffler wire holder
Ok guys just picked up the wc edition from my lhs. Hopefully he stocks the parts like he says. I was told you have to cut the plastic wire holder off in order to put the new alu holder on. Just want to make sure that is correct. Is there any other quick building tips I should know about?
Thanks in advance.
Thanks in advance.
#2302
Re: Muffler wire holder
Thanks in advance.
Thanks in advance.
You can place the alum. muffler stay on the carbon upper plate, from the upside!!!
No need to cut anything!!!!
#2303
Thanks in advance.
Thanks in advance.
*Oil the shock collar o-rings, this`ll make them run heaps smoother.
*Mount the front anti-roll bar flat.......vertical gives too much understeer.
*The front castor may have a bit of "play" in it once all the castor clips are mounted. To get rid of this play use a 1mm castor clip in addition to the ones supplied (NTC3`s are 1mm if you cant find a Kyosho 1mm castor clip).
* If youre building a non-WC RRR, get the aluminium brake hub holder to sue when you build the car (VZW205)
* If youre running a Protoform Mazda 6, mount the rear body posts on the inside of the shock tower....that way they wont come up underneath the rear wing.
* Dont over tighten the fuel tank mounting screws onto the upper deck.....these need to be free.
Cheers Andy
#2304
Thanks for the replies, Car is tinteresting with the F/R belt adjustments and the cay the pins are held in on the axles.
Too late on the cutting part .I am so impatiant. Oh well, maybe a good test if he can get the parts like he says.
I did notice slgit movement on the front upper arm. I still have my ntc3, so I will give it a whirl.
#2305
Originally posted by jeffreylin
They are close but definitely not touching. Mine has about 1mm of gap at the closest point.
#2306
Originally posted by joemugen
what have you found out about power supplies? i need to get one too, so just curious if you found anything good out. thanks in advance.
http://www.shopatron.com/index/166.0.4839.0.0.0.0
32 amp max 30 amp continuous
#2307
I got the KO Alinco:
#2308
by the way, how do you like the rrr so far?
#2309
Awesome. I've had it since it first came out and it's the all around best handling car I know.
#2310
do you ever run the 16t gear? if so, mine wears super fast. is there a way to harden it? or do you just replace very often?
