MUGEN SEIKI MRX5 >
MUGEN SEIKI MRX5
Like Tree3Likes
MUGEN SEIKI MRX5
Old 01-08-2011, 04:20 AM
  #1291
CHRISP76's Avatar
BTW, not able to change my avatar but definitely running MRX5....... with a 4 side belt!!!
CHRISP76 is offline
Old 01-08-2011, 05:58 AM
  #1292
ralphierace13's Avatar
Originally Posted by Motonica#1
Hey mate, I'm runnin the 4 side belt on mine, the 5 is way too long, I also wanna know WTF!!!!???
yer it gets to me its such a simple fix robert pietsch at the pre worlds said they were coming out with the new belt and it was fixed im going to shoot him an email on facebook see whats up also he said the new fix for the front knuckle stronger plastic would b out as well, but what they need is to use a 4mm tie rod up top on the front knuckle so it dont snap!!
ralphierace13 is offline
Old 01-08-2011, 07:08 PM
  #1293
Where did you get the low friction belts. I have not found a store that has them yet.
Thanks for the tip on the side belt it looked kind of long.
How are you all setting the belt tension on the front and side belts what I mean is how do you know if its to lose or to tight
Vector03cobra is offline
Old 01-08-2011, 08:37 PM
  #1294
go to www.brooklynhobbies.com it may not be listed on the site but get the number and call he has them..
well what i did is cause i run the 4 belt and its alittle snug were the the carbon fiber piece that holds the belt tensioner, the slot that lets the bearings go up and down i dremeled the top of the slot so the bearings can go up like 3mm more that allows me to run the 4 belt and i pull the mid shaft that holds the front belt all the way back so the front belt is tight.. the side belt will get even looser after a few runs, with the 5 belt if u push foward the middle shaft to make the 5 side belt tighter the front will skip.
Old 01-08-2011, 09:43 PM
  #1295
Thanks for the info.
Would any of the other car belts fit or work better? on the side or where ever? Like any of the serpent side belts?
Thanks for the info and help also.
Old 01-08-2011, 09:51 PM
  #1296
How is everyone doing with the radio receiver. I will be using a Airtronics M11 and wasnt sure if i should do Art's radio tray mod, or vent the case or just leave it be.
I saw pics of swaugers car at the great lakes raceusing the same radio and he had the reciver mounted in a unmoded radio case.
Thanks for any info and help
Old 01-09-2011, 05:57 AM
  #1297
ltrdude's Avatar
Trader Rating: 32 (100%+)
Default side belt pulley
Until Mugen comes up with a fix ,I make this side belt pulley .The pulley uses all the bearings and parts from the MRX-5 kit.I shipped the first batch to Brooklyn hobbies .Get ahold of Richie .
ltrdude is offline
Old 01-09-2011, 06:05 PM
  #1298
YLLIB's Avatar
NICE JOB!!
YLLIB is offline
Old 01-09-2011, 06:39 PM
  #1299
Steve Rossi's Avatar
Default fun times
Originally Posted by blis
Thought the Mugen crew might enjoy this too.
http://www.youtube.com/user/therealblis?feature=mhum
this still looks like a good ol bunch of fellas havin a good time love this video
Steve Rossi is offline
Old 01-09-2011, 07:20 PM
  #1300
J. Conley's Avatar
Cool clip. 1/8th scale under the lights!!!!!! I can only imagine how fast the cars would look at night.
J. Conley is offline
Old 01-10-2011, 10:58 AM
  #1301
YLLIB's Avatar
way cool. always nice to have an 1/8 scale to race on...
YLLIB is offline
Old 01-10-2011, 11:38 AM
  #1302
Roelof's Avatar
Something like this?
http://www.debaanbrekers.com/ftp/final.wmv
MRX4 with a Serpent McLaren GTR body and lots of lights.
http://www.youtube.com/watch?v=6mdOKo0YIMU
http://www.youtube.com/watch?v=MmZS_j8sK_s
It is fun.....
Roelof is offline
Old 01-10-2011, 06:02 PM
  #1303
We ran a heat race under the lights at the WINTERNATS one time
They look twice as fast !!!
jrice is offline
Old 01-11-2011, 10:43 PM
  #1304
Default Tire Sizes
What tire sizes are most of you using with the stock setup side pully
Tire sizes for qualifying
Tire sizes for mains 30 mins or longer
Old 01-12-2011, 05:40 AM
  #1305
MugenDrew's Avatar
Trader Rating: 36 (100%+)
29 tooth side pulley 66mm front, 73mm rear still seems to be the sweet spot, if your willing to run fresh cut tires every round. The main is gonna be up to the tire wear and layout. Everytime you run the car write down your starting and finishing diameters so you can monitor your tire wear. Other questions for the main, are you going to change tires(1/2 hr in a parking lot can be tough on tires), are you going to mix up the shores to compensate for wear, are you going to cut all four tires to different diameters to compensate for wear? Half hour at the Fort I would probabley start out with the left front .5mm larger than the right and the rear left say 1-1.5mm larger same shore. There is "no tire wear at the FORT" so to say, there maybe to much traction though...NOT! there is no such thing as to much grip only to low of a roll center
MugenDrew is offline
