Serpent 733 1/10 200mm touring
#1921
#1922
this is the one i use. i see the dimensions are slightly smaller than the one you listed.
#1923
#1924
thanks guys i just bought that one u posted up... i think it will work fine...
#1925
what body will be the most stable on this car?
#1926
Pinion
Will the 720 steel pinions work with the 733 spur gears?
#1927
#1928
Just finished building a 733 for a freind of mine, and i can say it was the easiest build of a 1/10th scale ive ever done! everything went together smooth, no bidding in the arms, and the drive train was free from the get go! This car is so easy to work on its a very well designed car! I look forward to getting one soon! I run the 966 but i think i need a 733!
#1929
what grease are you guys running on your 2 speed oneways? read a few pages back serpent oneway lube is no good for the new style bearings, is this actually the case?
#1932
hey guys im building my 733 and im up to setting the clutch. i cant get the .7mm gap, im running a Novarossi 3SCT tuned engine and it almost like the bolt that holds the thrust bearing holder inplace isnt long enough to bottom out in the crankshaft. im using the flywheel cone that came with the engine, could i take a little bit off the cone, would this help or am i doing something wrong.
Thanks guys
Thanks guys
#1933
Thanks guys
Thanks guys
DJ Apolaro
#1935
