Serpent 733 1/10 200mm touring
#1171
If you are not having issues than I would not change what you are doing. Maybe your enviroment allows you to get away with just the oil. I would hate for you to change and then have a problem.
DJ Apolaro
DJ Apolaro
#1172
serpent 733
Dj are you going to run this weekend FORGASS SERIES RACE #1 ...?
#1173
serpent 733
battery-pack Lipo
How does a lipo battery , I hear it can break if not charge right after it was use?
a little help and info.
#1174
Ok DJ, thanks!
Will keep that in mind....
#1175
I am not going on Saturday for the practise or Quals, but should be there Sunday for the Finals. I will run on Sunday most likely.
DJ Apolaro
DJ Apolaro
#1176
Who is jjrctech????
#1177
Grease or oil, anything is better then nothing. I personaly have never had a oneway problem so Im not too worried about it.
#1179
body will add about 100g to yr 1750g...
seems like the weight of 733 can vary from 1710-1850g...that's a huge margin.
by the way, will it be fine if i change those m2.5 self tap screws for the diffs to normal m2.5 machine screws?
#1180
Why would you want to change them anyway?
#1182
with the weight of the cars, mine was heavy. was 1805gr.
this is with a 1600mah nimh pack and no holes in my body yet. now i have LiFe pack, im sure to shed 30 grams. once the lightweight solid axle comes for the front, im sure to shed even more, making the car around the 1750grams. thats a comfortable weight margin for being legal. due to our rules, min weight is 1725grams. any less and you are in trouble.
#1183
a couple of my self-tap screw got stripped at the "+" and became 'rounded'; couldn't find any m2.5 self-tap screws at my lhs and those shops selling screws and nuts. what's available is only the machine m2.5 screws or m3 self-tap screws...
#1184
only self tap screw will hold... using machine screws there will just be asking for trouble....
#1185
Are u serious? Well i will put the body on and measure on another scale. so we are comparing a full rtr weight without fuel right?
