Serpent 710
OK guys, heating the engine helped but I have another problem, I have a cheap duratrax starter box and the ns12s5 is to stong for this box, I had to use my friends old stater box to get the engine going, but he had an old one I dont even know what it was, so my question to you is what starter are you guys using, I need to get another one
New 900Mah battery pack for 710
I'm using the Serpent starter box.
I sometimes have trouble starting some of my engines when I use my cheap battery packs.
Some of the guys have suggested using a 12V.
Re: New 900Mah battery pack for 710
Serpent Battery-set 5-cell 900mA NEW S-705-835-710. Complete pre made battery pack - Comes complete with plug - The pack contains 5 730Mah AAA batteries - Suitable for the Serpent 705 and 710 and 835.
801173
It says it's 900mAh, but later it says it contains 5 730mAh AAA batteries.
Originally posted by cyba888
Just ran my Mazda 6 body today and all I can say is WOW I been using the Stratus this whole time and to me the Mazda feels much better on the corners and is more stable as well. I aint going back to the stratus body.
ZIZU: good move! sell your 710 and focus your energies into the car/s that you really like!
stankulas
Im using the front diff on my car, Its working well on my local tight and twisty track. better brakes and corners like a train on rails
The only part i seem to be breaking often is the thrust bearing im lubeing it every 20 mins or so of racing but the car is using an alarming rate of them
Are you suppose to lube your bearings? I have changed mine a few times because it wasnt smooth and gritty which was from the wheel hubs, maybe due to an accident that might have damaged it. So far my 710 has been running good, 1 gallon tank and the only meaintenance I did was rebuild the rear diff. Other than that its still running fine.
Originally posted by mrblond03
stankulas
stankulas
Anyone using a Ko Propo Electric Switch for their 710, is there room for it? The only downside is that it drains the batteries even when not in use. What are your thoughts on getting one?
thanks glad to here that i think i am going to buy one and try it thanks
stankulas
stankulas
On the clutch Julius
I have built my clutch to Glen's spec but its still a problem
Hi guys
Here is the link for pictures I posted on our forum on how to make the rear bumper for S710 from parts of S705.
Hope you like'it !
http://mdm.zrcalo.si/forum/viewtopic.php?t=3615
Hope you like'it !
I just got information that some of the 710 alum. and the plastic parts are made by 3Racing and some company in China. That's why Serpent parts are very very cheap compare to the old days... Is this true?
