Serpent 710
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Winternats 2004
Originally posted by Sow&Steady
When I was younger, as a student and it was already cold way back then!
On top of this, students could never afford heating!
Sunday 03 October, Sunday 17 October, Sunday 31 October 2004.
Sunday 07 November, Sunday 07 November 2004.
You can't get out now my friend ... plenty of dates to choose from!
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Winternats 2004
Originally posted by markp27
Hmmmmm Okt 3 looks ok Where abouts is the track? I can fly to Stanstead very cheaply and quickly (used to have a house near there).
These are the specs for the S9550
SPECS: Speed: .14 Sec/60 Deg @ 4.8V or .11 sec/60 deg @ 6V
Torque: 67 oz/in @ 4.8V - 83 oz/in @ 6V
(4.8 kg/cm @ 4.8V - 6.0 kg/cm @ 6V)
Futaba S9451
SPECS: Speed: .13 Sec/60 Degrees @4.8V - .10 Sec/60 Degrees @ 6V
Torque: 97 oz/in @ 4.8V - 121 oz/in @ 6V
(7.0 kg/cm @ 4.8V - 8.7 kg/cm @ 6V)
It seems that the S9451 has 30% more torque. Do you think it will make a big difference if I were to use it for drag brake? I was just hoping that if I were to get the S9451 and use it for drag brake then it shouldnt put as much stress on the servo compared to the S9550? What do you guys think....
Futaba S9451
Originally posted by GoldFinger
I believe yours is "team" batch
Re: Re: Re: Re: Re: Re: Re: Helios
I got a problem with my wingman coz he is still faster than me so I can not tell him to do this and that.
So this is your new trick to get 6-7 minutes?
Originally posted by crashed_1
Yup. If you plug in the batts b4 the transmitter...the servos will twitch a little but then it won't function when the transmitter in on.
Crashed, if your servo acts like that it would be a problem when attending a big race with tight schedule.
Why don't you just say it ... D is a good pitman.
Re: Helios
Originally posted by Titan
Crashed_1,
Thanks dude.
Guys,
I was also wondering if I should get KO Digis 2344 or 2343? I am leaning towards the 2344 servo with lotsa torque.. What do you guys think?
Crashed_1,
Thanks dude.
Guys,
We've discussed this several times.
I like the high torque for my steering.
Others prefer the high speed.
Here's Josh Cyrul's opinion on torque versus speed.
Originally posted by Josh Cyrul
PSI Racing - I prefer the higher torque in my gas cars. I used to always choose the speed for the steering but after I tested a few different servos I then opted for the high torque as I liked the feel - less twitchy off center but it did seem to have more steering in the higher speed (higher load) corners.
Re: To Isolate or not is the question?
Originally posted by wolfejohne
I am at the stage of putting the servos in my car, and would like to know if I should isolate the servos from mechanical vibration? In the past (15 years) when I raced Hydroplanes we used the rubber isolators that were supplied with the servos. When I changed to Electric 12th and 10th pan cars we mounted the servos solid with no isolators. Now 10 years later with gas cars what is the correct thing to do? I am using Futaba S9350 for steering & S9405 for the throttle. When I try to use the rubber mounts that came with the servos, the hardware supplied is not long enough and the holes in the steering mount are to large the support the brass inserts. I have a picture of Rene Cornella’s 710 I took at the Winternats and it looks like he does not use any servo isolation ( I think).
I tried to post a picture but the file size was two large.
Cluth bell Gear Spacer?
I found on Mytsn site a Important Note about adding a small spacer (#802511) between the first and second pinion gears. Is this still required or is it optional? I have a black color 2nd gear and a brown / golden 1st gear. I can see where it helps line up the pinion gears with the two speed spur gears.
Re: Cluth bell Gear Spacer?
Re: Re: Re: New to Nitro
Originally posted by Pyramid
Only 2 selection can be made on the back (behind module), either normal mode or High Response mode. High Responde mode consist of another 2 settings from the LCD menu (not switch on the back) which is Advance or Super HRS by selecting either 2-3 chanel on the system mode menu. I just read the manual yesterday just gotta try it first then. With angled extension wheel.. it feels better balance for me. The style somewhat a bit complicated
and with the angled extension...you just save yer wrist from the long painful main.
i just wish i can use the fail safe, which is not allowed when using the super HRS. oh well, im using special crystal anyway...so far, at my place no one got it
