Serpent 710
#7306
Re: Re: Give Credit to those whop deserve Credit!
Originally posted by BaxterC
My humblest appologies, I posted a link to the site, then did some reading and found the article and thought that this would be great on for you guys, I forgot to put in that it was a copy\paste deal... SORRY
#7307
Re: Re: Re: Give Credit to those whop deserve Credit!
Originally posted by kreidel
Yea..nice plagiarism!! Nice catch Schrijver99
#7308
Hey, Look what I found... some more little tidbits...
Nitromethane
Nitromethane is a fuel that is used in racing, particularily in drag racing, to provide more power. When you hear the term "nitro-burning funny car" or "top-fuel dragster", that means that the engine burns nitromethane.
Nitromethane's chemical formula is CH3NO2. For comparison, gasoline is typically C8H18. The oxygen in nitromethane's molecular structure means that nitromethane does not need as much atmospheric oxygen to burn -- part of the oxygen needed to burn nitromethane is carried in the fuel itself.
You need 14.6 pounds of air to burn a pound of gasoline, and only 1.7 pounds of air for the same amount of nitromethane to burn. A cylinder can only hold so much air on each stoke, and with that amount of air you can burn 8.7 times more nitromethane than gasoline. By pumping in 8.7 times as much nitromethane per stroke, you get about 2.4 times more power per stroke. Gasoline provides 18,000 BTU/pound. Nitromethane provides 5,000 BTU/pound. The amount of nitromethane also provides some cooling, making the charge a bit denser and increasing power.
The flamefront does not move as quickly in nitromethane as it does in gasoline, meaning that there is not enough time to burn all the nitromethane in the cylinder when the engine is running at high RPM. When the exhaust valve opens, burning nitromethane flows out through the exhaust pipe. That is why funny cars and dragsters "spit fire" from their exhaust pipes.
This I found here
Nitromethane
This I found here
#7309
Guys, If you want, please PM me if you would like me to put you pics, and I will put articles on there, going to try and get as much info in one place as I can, It is only about Serpent 710... This will be OUR site... for ALL of us.
#7310
#7311
Originally posted by Palmaris Europe
Guess that counts me out. I only run a 705/Yokomo GT4 hybrid.
#7312
#7314
Which half is which?
#7315
You know... If you go for a 710, you wont need to make do with a half and half... Only joking...
#7316
#7318
Originally posted by markp27
There's a half-ling amongst us!
As for which is which. I'll never tell. Its secret . j/k
Mainly 705 with Yok suspension. Really helps the steering on the car.
#7319
Yeah, but that takes away the fun part. I prefer to cut and paste parts to make a good car from what I have laying around. And at the price of the 710 in the UK I dont think I would shell out for it for 5months use.
#7320
RC mushroom has it at $365
