Serpent 710
#3406
Originally posted by sparksy
And on a side note.... is it just me that gets pissed off when someone cant be bothered to trim the picture they want to post? I ***ing hate having to scroll each subsequent message side to side to read it.
The quality of larger pictures might suffer when trimming them down too much,that's why it's just better to attach them to the post and everyone can just click on them if they want to view them.
I feel your pain sparksy !
#3407
Re: Re: Fuel Tank & Pressure Line!
Originally posted by S710_Nut
Hey Guys,
Something i noticed today was that while being refueled when the lid is closed it would inject a heap of fuel into the carby and flood the engine and on numerous occasions the motor ending up stalling. Any suggestions? Do i need to run a longer pressure line from the exhaust or are we simply filling the tank with too much fuel?
SN
Hey Guys,
SN
About shutting the lid too quickly is a joke, you dont need to worry about it.
Cheers Bill
#3408
Re: Re: Re: Fuel Tank & Pressure Line!
Originally posted by BG
The problem lies with the tank lid. Replace the AFL seal on the lid. The spring tension on the AFL lid alone is enough to shut the lid. If you need to press it to close the lid properly then its a tank problem, replace the whole tank.
Cheers Bill
Cheers Bill
Bill, not bad suggestions but I've used these AFL caps since they first came out during the Pro days and never had problems.
Maybe the first thing to check is the length and hole size of the fuel line as well as the pressure line from the exhaust. Someone also mentioned the possibility of the HSN being too rich.
I think something more basic is out of whack for the carb to be flooded just by shutting the tank cap.
Maybe I'm wrong ...
#3409
Sparksy I also remember flooding the 835 with fuel the first time I pitted for you. How's the 710 going.
#3410
Tank Cap
S710, just do a quick check for your low needle setting.
Open the throttle fully for 2-3 second(off ground) then put your car down (in track). Let it idle for 10 sec or so..
Snap your trigger, if your engine goes wroooo and stalls then it should to rich. No matter how your tank cap, your engine is loaded up quickly when refuelling.
If your car goes da.. da (some hesitation) before it jumps, then it should be a bit lean, but it should be OK if you like it. Just make sure your car does not creep even a little.
In case you like this low needle setup, tighten your clutch bit more to make sure it does not engange when idle.
There is no perfect idle, as long as you have enough power on bottom to mid range even with higher rpm idle setup.
And no problem with snapping the cap after refuelling.
Just remember, we do not have an event call :
"LONGEST IDLE CONTEST"
#3411
Oppss... Got too excited looking at the WRC04.
#3412
Re: Re: Re: Re: Silver Stone Track
Originally posted by Sow&Steady
Yes, I plan to go up because it coincides with Raya Haji. From the pictures it looks great, will let you know!
#3413
Well, after usuall wasting of my evening times reading some others car threads (we sell cars, need to know some info on others.. you know.. ), I came to realize that this is, indeed, the most informative threads (at least from what I've visited). Just like someone here mentioned before.
#3414
Suitable Synthesized Receivers
Fingers crossed, hopefully ordering my new 710 within the next couple of weeks can anyone advise whether any of the third party Synthesized Receivers will fit in the receiver box and work with my Ko Propo EX11 (Presto) Transmitter, as I'm having to buy a new Receiver just fancied a Synthesized one ready for when I eventually change the Transmitter.
Cheers
Mark
Cheers
Mark
#3415
Futaba 3PKs will launch it synthesized recvs by end of march along with its synthesized module... it would have been a better upgrade
#3416
#3417
Originally posted by dino.tw
People will not doubt or regret on the most expensive stuff.jajaja.....
#3418
Originally posted by InitialD
Pyramid, that's an understatement !
#3419
Originally posted by jfc_tech
Hi there D....just curious when u said, "Wide Open throttle"...is that full pull on the trigger...like u want it to go very fast
I just break-in my max idling with fuel spitting out on & off hot & cold 4 tanks. afterwards, now on 8 tank on track rich reaching only max 90deg Celcius without body....am i doing it wrong
im gonna join the Kuching race and still confused on the hole on the front windscreen
#3420
I'm glad you did not say it "underdog" (if I remember it correctly), it might turns ugly in here..
