Serpent 710
#3241
I agree that all cars have their pros and cons. Just have fun with what you have and enjoy it. I see people with all sorts of cars at my local track, even the hobby shop owner says they are all competitive, its all personal preference. Reason I bought a Serpent was #1 the car was just released and I know a new one wont be out anytime soon. #2 I always owned japanese made cars so I wanted to try something different
The fastest lap record at my local track in Taiwan is a Serpent 710
#3242
Originally posted by Rookie Solara
If you are talking about the 5 cells AAA on your 710.....after your race day, just leave the battery alone (DO NOT discharge) and 6 days later, before your next race, peak the battery (make sure not use more then 1AMP to charge AAA) then you should be all set
Ni-Mh does not required discharge, you can do CYCLE on the batteries, but again, these are your receiver pack, and you are not running those batteries like ppl do to race their elect TC, so there is no reason to drain and charge like the old time Ni-Cd batteries.
I want to charge my transmitter batteries as well, should that also abe charged at under 1amp?
#3244
For those want to see the OPTIONS coming from Serpent, here is the pictures......
I like the idea of front Ball diff (for tight small track, that is a must)...then for those VDS lover........low front shock towers along with front bumper and mounting plate.
Not to mention, this ia a must for me..........lightweight Centax 3 housing...
#3245
Originally posted by cyba888
Yes Iam talking about the 5 AAA batteries. How long does it take to charge it completely? I charged it at .8 amp and it took well over 40 minutes using the Tekin BC112. Actually it was more time but I just stopped it because I needed to test the servos.
for 5 cells AAA with 1 Amps charge and 3V delta peak.....it usually take me 35-40 minutes to FULLY charge them from zero, I usually don't drain the batteries before charge, but I occasionly CYCTLE the pack several times to peak the batteries, when I finish the race, leave the car on the bench, then charge the pack for the upcoming race, usually will take me 25-30 minutes to peak the pack depends on how much MAH left on the packs.
Yes, charge your AA with 1amps is fine too, but for AA, you can go up to 1.2 but defintiely no more then 1.5amps if you don't have 1 hours to charge your pack.
#3246
hope they release the ball diff already. been waiting too long. got two of them ordered already and still waiting.
its a must for our local track!
any idea... or does anyone know when these items will be available?
#3247
Another question
Do you guys use the transmitter to cut off the engine or do you manually cut it off by squeezing the fuel line? Which is better and why?
Another question
Several ways to shut off your engine after race...
(1) Ppl like to push the thumb onto your intake (foam filter usually) so no fresh air going toward the engine chamber and the engine will shut down......however, ppl also say doing that will PUSH all the garbage that the foam filler collecting INTO the carb, and that is NOT the best thing to do for your MAX enigne (If I remember correctly, you said you just got a mod engine - MAX right....? )
(2) I do that myself, get yourself a race mechanic glove and jam your thumb to the flywheel..........it is NOT that scary then what you thing....as long as you hit it FAST and HARD, .12 engine are easy to stop..........ppl do that on .21 engine all the time.
(3)....squeeze the fuel line.........no fuel, no power.
(4).......put your thumb (with gloove of course) to the exhaust tip, back pressure will shut down the engine in several seconds UNLESS your engine running extreme lean.
#3248
That list was posted by Serpent HQ (Europe).......so Serpent USA will get the 2nd shippment.......of course.
For those who want to see what 3Racing (from HK) will do for Serpent 710......take a look here.
http://www.3racing.com.hk/3racing/op...kit=SERPENT710
To be honest, a car like 710..........I don't see too many rooms for OPTIONS.........alum pulleys, alum arms, alum uprights.....those are for HPI RS4, and I don't know why ppl will need those on 710....but for those SSG lover, 3Racing does have a lot of carbon fiber replacement if you like different color SSG fiber on your 710....but I heard SSG does have more flex then typical woven carbon fiber.......again, why SSG?
#3250
Another question
Another question
Setting the transmitter to close off your carb is ok but you have to be careful not to cut your engine off accidentally. I know a near foolproof way can be done with the upmarket radio systems but why risk it?
#3251
Transmitter cannot cut off engine....even when you are in FULL brake positive unless you set your idle spacing incorrectly, but if you do that, your engine should not be started at the beginning.
#3252
Just finished my new 710. I put my alum. shocks from the 705 just for the pics.Yes, cvd's and alum. shock bodies is really all you'll need.
