Serpent 710
Re: Re: Re: Re: Re: Re: New parts online
Originally posted by InitialD
I always use office address. I think it's safer plus most of the time, the package arrives when you're at work and you're there to receive it. Now comes the best part (not mentioned in the FAQ). The wifey does not see this RC stuff coming as a package as well.
Re: Re: Re: Re: Re: Re: Re: Re: Re: New parts online
Originally posted by markp27
I'm impressed, D - you've made it too chapter 3 already: Multi-Object hiding
Not to mention what's hiding in the boot of his car!
Re: In the pit.
Originally posted by sn4il
Hello.
Today i had my first crash with my new serpent. It was driver mistake. (actually mechanic mistake). For rx battery i used servo extension. After couple tanks i decide to recharge my battery. Battery was still in good shape because i just pumped in like 210 mah. I put everything together and took it for the ride. In the first minute something went wrong. Fail safe was activated and my car stopped. Car was away from me so after couple seconds when everything went back to normal i decided to bring it closer.
Then sudenly car gained top speed and went straight to the other side of parking lot. Oh man that parking lot is huge, like 1/2 a mile. I didnt have control over it. Car hit the curb at top speed and went in the air like 8 ft high. When it hit the ground it sat against the curb and the motor was still running. The time i got there (it was far ) the engine died. Tires were grinded down to the rims.
Losts:
chasis - broke in the front
radio plate- broke at one corner (car hit the carb with left wheel)
body - cracked
couple of plastic parts at front and aluminum anti roll bars
I didnt check the servos yet and i hope my engine is ok.
The weird thing is that when i crashed and went to the crash side i noticed that another guy was driving his rc car. I dont think it was radio interferrance it looked more like servo extension got disconnected and rx lost the power.
Well that was good lesson for me, i know ill be back out there next saturday Im not the kind of guy that gives up after a crash.
Max
Hello.
Losts:
body - cracked
Max
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New parts online
Another good possibility We'd better get Sow to check out MS's car at the worlds for special weight increasing parts
Now ... just need to make sure spy does not forget!
Mark, quick! Add it to the FAQ ... then you'll have another updated version!
Re: In the pit.
Max
Max
Like they say ... A Winner Never Quits!
but I had a PCM receiver
Well... is there any new chasis for Serpent or just the stock one?
Max
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New parts online
Bet D has to do all the shopping, just so Wifey doesn't see in the boot
What about the one where wifey asks:- "Is that a different car?"
D anwers:- "Errr yes, it's Crashed, I'm trying to fix it for him, you know ... he's busy feeding his baby and all ... the poor guy. We have a race this weekend."
I have PCM receiver, thats why i think that receiver lost power suddenly due to disconect of servo extension.
Max
Max
Yeah, if the power plug falls out, then even the fail safe wont help you. You can however put some very powerful elastic bands around the throttle linkage on the carb, so if the power does fail, then the car goes to idle.
Any1 using this setup?
Max
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New parts online
I'm impressed Mark, I thought only married men knew such tricks!
Ehm, Sow, you have to help me think of a good excuse about where I am this coming weekend
Like my cycling team mate who told his wife the new wheels she saw were actually mine, which I had lent him, as I didn't use them any more Coward!!!
Yeah i read about it, what about servo response, it has to put more torque because of that band or spring right?
Max
Max
I personally don't use this method, but maybe one day I will regret it
Re: In the pit.
Hello.
Losts:
body - cracked
Max
Hello.
Losts:
body - cracked
Max
Wlell sorry to here about your mishap. Sounds like someone was on your channell and took over your car.Hope you get it repaired correctly and no more is damaged than you can see.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: New parts online
