MTX 5
#1321
RC Market's website is one the slowest that I know of, and a lot of patience is needed when using it. It is that slow that it probably wouldn't open at all, if your internet connection speed is already slow. Trying another browser helps sometimes with slow speeds, the three browsers you could try are: Google Chrome, Mozilla Firefox and Internet Explorer.
Kindest regards,
Lars.
Kindest regards,
Lars.
#1322
finally release
part number B0542
part number B0542
#1323
hey mate,
I havent run my car yet but im thinking its from chassie flex. I run my nt1 few years ago with a carbon fibre chassie and it stripped gears due to flex and it was fine before i made the change. hope this helps but im thinking a thicker chassie is the only way to stop it. But i will see how my car goes later this week.
cheers
fergo
cheers
fergo
#1326
hey mate,
cheers
fergo
cheers
fergo
There is no point holding the car and bending it as this isn't an indication of how the car flexes on the track, so IMHO, there's no point checking for "flex" like this.
the stripping comes from a poorly set two speed, ie one set screwed in more than the other or the gap being too small, or the two speed remaining engaged when going from 2nd to 1st gear. The issue of remaining engaged is related to the above issue (set screws uneven, or gap too small. The small gap means the shoes remain grabing just a bit and keeping the gears engaged, this is when it can strip).
stripping can also be caused by massive curb hopping. I did a fair bit of this at lilydale so i can say that the gears can take a fair bit of abuse
Stripping can also be caused by the gears being warped. You can warp the gears by screwing in the screws uneven, or into cold plastic. heat up the gears, and or pre tap the holes before screwing in the gear holders. the gears should spin true or very close to true.
Make sure you set the gear/engine gap with the larger spur off. leave the smallest of gaps. just enough so the spur spins without making a binding sound.
make sure the pinions are not worn out or sharp.
finally make sure that the larger pinion is not touching or close to touching the larger spur when the clutch is fully engaged. If the endplay is big enough, a warped gear could potentially grab the larger pinion at some points. Shim out the larger spur if needed.
happy racing
#1330
mtx-5 stripping gears
after being at the australian titles and helping one of the guys running this car,one solution is to keep the split between the gears the same (ie.odd gap in both pinions and 2sp 15/20 53/48).the guy i helped tried a different 2sp gear and it stipped but went back and had no problems after that. i hope this little bit of lnfo may help in some way.
#1331
#1332
Gear stripping
Hi guys
Just a bit of information about our experience with gear stripping, we ran two cars and one developed a major gear stripping problem. The complete rear shaft and all associated parts was sapped from the good car to the one stripping gears . All this did was to continue to strip gears that had been running on the good car.
The reason and solution.. We found that as a result of the clutch bearing stopper not been completely centered the clutch shoe at worn at angle. This then appeared to engage the clutch bell at a slight angle and consequently would not run true.
We replaced the clutch shoe only (as we had already replaced the bearing stopper) and Wulla , no more stripped gears, the car ran at a 3 hour enduro today with no gear stripping issues at all. Hope this helps
#1334
#1335
IN PAGE 40 it shows Pietch's car with different back shaft base. Maybe this base exists for not stripping gears? Because the shaft may have a gap.
