MTX 5
Old 07-01-2013, 03:17 PM
  #2821
shanwright's Avatar
Trader Rating: 25 (100%+)
Thumbs up Great to see the car has got the pace!
It was good to see the pace he had with the MTX5.
It has been decidedly quite for For MTX 5 podium spots for a while.
Shame about the flame outs great caliber to chase down the field and clock the fastest lap time, good work Robert.
The brace Robert is using supports the two transmission bulkheads side to side.
I was surprised to see he was using the standard chassis, I suspect it gives a good balance of flex at the rear.
Steve H
Last edited by shanwright; 07-02-2013 at 02:32 AM. Reason: Dam auto spell checker. Lol
shanwright is offline
Old 07-01-2013, 04:56 PM
  #2822
GMartinez's Avatar
Trader Rating: 91 (100%+)
Originally Posted by Perez
Did you see that set screw on the front diff? bleeder maybe?
http://ens.redrc.net/wp-content/uplo...06/Sat_cf7.jpg
I think it is more to refill the diff since he is sealing it
GMartinez is offline
Old 07-03-2013, 02:29 PM
  #2823
shanwright's Avatar
Thumbs up Roberst ENS setup
Check out the setup sheet Robert published from the ENS.
The front dif. Oil weight is interesting
Springs ? Really.
http://www.mugenseiki.com/download/s...ens2013_rp.pdf
Steve H
Old 07-03-2013, 03:17 PM
  #2824
NITTO550's Avatar
What are those springs on the shock shafts?
NITTO550 is offline
Old 07-03-2013, 08:26 PM
  #2825
GMartinez's Avatar
electric touring springs
Old 07-03-2013, 08:33 PM
  #2826
shanwright's Avatar
Wink
Maybe two speed springs and notice the shim washer to adjust the bump stop.
Steve h
Old 07-03-2013, 08:44 PM
  #2827
NITTO550's Avatar
Is this ens setup suppose to be the same car shown in the photo gallery? Where is the solid spool
NITTO550 is offline
Old 07-03-2013, 08:45 PM
  #2828
NITTO550's Avatar
Is it just me or is shimos setup come up blank?
NITTO550 is offline
Old 07-03-2013, 09:26 PM
  #2829
FF25510's Avatar
no problem here, it works
FF25510 is offline
Old 07-03-2013, 09:28 PM
  #2830
shanwright's Avatar
Talking
I wonder just how long that grub screw in the front dif?? Lol
Old 07-04-2013, 02:17 PM
  #2831
danjoy25's Avatar
Trader Rating: 38 (100%+)
anyone looking for a good setup I selling my car as no time to race anymore
http://www.rctech.net/forum/australi...kage-sale.html
Can ship anywhere
danjoy25 is offline
Old 07-04-2013, 03:57 PM
  #2832
gotmotor's Avatar
C'mon man thats a set screw to lock the diff
gotmotor is offline
Old 07-07-2013, 11:02 PM
  #2833
Quick question. Higher diff weight = more or less traction? I seem to have too much steering with 80k oil in the rear. Should I go heavier or lighter?
jeromakazi is offline
Old 07-09-2013, 09:37 PM
  #2834
NITTO550's Avatar
• To make a gear differential LIGHTER, fill it with thinner oil.
• To make a gear differential HEAVIER, fill it with thicker oil.
EFFECTS OF FRONT GEAR DIFFERENTIAL ADJUSTMENT
Lighter Front Differential (thinner oil)
• Decreases understeer
• Decreases stability under braking and acceleration
• Increases chance of traction roll
Heavier Front Differential(thicker oil)
• Increases understeer
• Increases stability under braking and acceleration
• Reduces chance of traction roll
EFFECTS OF REAR GEAR DIFFERENTIAL ADJUSTMENT
Lighter Rear Differential (thinner oil)
• Decreases on-throttle steering
• Less acceleration if the grip is there
• Less predictable car (cars with very “loose” diffs have a tendency to understeer heavily under throttle and turn-in oversteer as soon as you lift)
• Less on-throttle oversteer (snap-oversteer)
• Less turn-in understeer
• Less stable under braking
Heavier Rear Differential (thicker oil)
• Increases on-throttle steering
• Better acceleration if the grip is there
• More predictable car (cars with very “loose” diffs have a tendency to understeer heavily under throttle and turn-in oversteer as soon as you lift)
• More on-throttle oversteer (snap-oversteer)
• More turn-in understeer
• More stable under braking
TRACTION CONSIDERATIONS:
* The higher the traction, the lighter the diff oil up front, and the heavier at the rear.
* The lesser the traction, the heavier the diff oil up front, and the lighter at the rear.
Got this from the xray site
NITTO550 is offline
Old 07-09-2013, 11:58 PM
  #2835
bigbank66's Avatar
Rome...at speedworld when he spray u can use up to 80K in the rear an on regular days 60k works well...I went down as far as 30k an the car pushed like a truck...so no lower than 50k..
bigbank66 is offline
