Old 09-08-2011, 09:41 AM   #826
choisan's Avatar
Mugen won't risk to make something may hurt its brand
choisan is offline   Reply With Quote
Old 09-08-2011, 09:50 AM   #827
Originally Posted by Bishop View Post
Any standard sized flat pack should work, part numbers there are almost irreverent, I'll be getting a flat LiFe pack myself, by the looks of it that is what Robert was running at the EC.
I'm actually surprised Mugen and other brands don't do a branded LiFe pack yet, I can't stand NiMh anything anymore...
How are the part numbers irrelevant? mugen did a branded pack for the 4 and looks like they are for the 5. They have different part numbers so wondered if it was a different size.
aaron w is offline   Reply With Quote
Old 09-08-2011, 12:18 PM   #828
Seisick's Avatar
actually is a lipo as he is running high voltage servos, its the lipo from LRP 2400mah, enought
for 2 hours racing
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 09-08-2011, 12:37 PM   #829
Sorry to disagree but I think Robert use two servos Sanwa (Airtronics) SRG-BL Low Profile Servo (6V) if he had to use a lipo voltage converter. Can be seen in the photos because the SRG-BL are the only ones who have your ID horizontally.
"Pegatinaman"
MTX4R/Novarossi 353-2660/Spektrum DX3S
Protoform P37/Nitrolux Fuel
pegatinaman is offline   Reply With Quote
Old 09-08-2011, 02:07 PM   #830
spenzalii's Avatar
Send a message via AIM to spenzalii
I'd like to see a shot of the radio box if possible. Looks very compact. Can't tell how hard it would be to plug in and unplug the battery from the radio (a switch is out ofthe question it would seem).
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 09-08-2011, 03:11 PM   #831
Seisick's Avatar
yep youre correct, so its a life for sure
HobbymaniA
GoT MuGeN?
Old 09-08-2011, 04:59 PM   #832
Yeah SEISICK, its a LRP VTEC LiFePo RX-Pack 2/3A Straight 1600...
"Pegatinaman"
Old 09-08-2011, 06:21 PM   #833
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
My kit is on the way.
I got 2 of the batteries coming so hope it fits.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 09-08-2011, 08:41 PM   #834
Tom.B's Avatar
Dan, i got my kit already The only problem i'm concerned about is i asked Murnan to put my order on hold, then a few days ago asked him to go agead witht he order...yet i haven't heard back from him yet, and i need the engine by the end of this month Hopefully i get my RB in time.
I'll post some build pics over the next few days
Tom.B is offline   Reply With Quote
Old 09-08-2011, 09:09 PM   #835
Mugenville's Avatar
Trader Rating: 25 (100%+)
Just get a pic of one Tomas and use that lol, if you want i can post you my unused MM JLR to use for now
Proud team member of "Team Mugenites" 2008 PDNR 2.4 Hr Victor's
Just finishing a race is a victory in itself
Jeremy Clarkson
"When you push a car past 180mph, the world starts to get awfully fuzzy. When you go past 200mph it actually blurs. The Bugatti Veyron is mind-blowingly, stunningly brilliant. It deserves 12 stars. Simply as good and as fast as it gets"
Mugenville is offline   Reply With Quote
Old 09-09-2011, 01:26 AM   #836
It 's a LRP 1600 mah LiFe ... I also use that
nazarc is offline   Reply With Quote
Old 09-09-2011, 01:46 AM   #837
Bishop's Avatar
Because a flat RX pack is a flat RC pack, like a hump pack is a hump pack, they are standardized sizes, unless Mugen went out of their way to create a new pack size, it's all going to be much the same.
Given the pack in the 5 is mounted higher and to the left now, I'd say most will run a LiPo or LiFe, cause it just makes sense to reduce the weight of something now above the chassis line.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-11-2011, 02:02 AM   #838
just some things i noticed whilst building the MTX5:
the instructions are not clear, and if it's the first time you build a kit, or even if it isn't, you will probably get a few things wrong and realise halfway through assembly. For example, the screw sizes aren't shown 1:1 so unless you have verniers you need to guess the size. There is no tips on assembly, ie (do this first, then this second) so you need to guess a few things.
the diffs are tiny!
the internals are the diameter of a 26 tooth pulley!, that's super small
they weight next to nothing
Also, it isn't in the instructions, but it looks like you can use grub screws to adjust the height of the front top arms.
Just a word of note when assembling the gear holders to the gears: place the gears in the oven to warm them up, this will make it easier to insert the screws. i set the oven at around 80 celcius. Because of the hard carbon plastic, i found that when i assembled it cold the first gear was very warped. I placed the gear in the oven, then assembled it and it was rolling a lot more truer.
by the way, i found some small cracks on the other side of the gears where the screw comes out from, i'm assuming these occured when i inserted the screws whilst the plastic was cold
TomB is offline   Reply With Quote
Old 09-12-2011, 12:05 AM   #839
Arahawak's Avatar
Trader Rating: 32 (100%+)
TomB, 1:1 screw comparison is on the 2nd page if I remember correctly.. The only troublesome thing is, if unsure able the screw size, is having to keep referring back to that page..
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 09-12-2011, 06:12 AM   #840
Les
Les's Avatar
Has any one got the assembled ready to race weight of the MTX5.
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
