MTX 5
Old 09-19-2013 | 02:14 PM
  #2911
Originally Posted by tonyhalandri
Give us the mugen part no for these springs...
H0764 - hard
H0767 - super hard
H0774 - ultra
SebO is offline
Old 09-19-2013 | 02:57 PM
  #2912
aturbotony's Avatar
Default Knack racing
I have the Knack Racing side brace on my MTX5 and It has not stripped any gear what so ever.... Also it made the car feel really good on the track. Oh! I have the first version of the MTX5 too! No new gears and none of that new stuff on the new car. If I were you I would invest in one of those brace's
aturbotony is offline
Old 09-19-2013 | 03:05 PM
  #2913
aturbotony's Avatar
Default clutch set-up
Originally Posted by NITTO550
I see that the original clutch spring is too soft. Also loses tension fast. Right now I'm using the mugen ultra hard for the 1/8
One thing I noticed on the clutch is that the car uses a aluminum clutch nut. We all know when aluminum gets hot it expands. After that the clutch nut will back off and there goes that perfect clutch set-up you had. So I put the old steel one on and my clutch never changed on me during the race!!!! A little something for you guys to try..... And the ultra hard spring is the ticket.
Also I put a blue clutch shoe on it....POW!!!! off every corner.
Old 09-19-2013 | 05:54 PM
  #2914
NITTO550's Avatar
Good point Tony, the clutch spring nut will back off, and blue loctite will eat away at it. What BLUE shoe are u talking about?
NITTO550 is offline
Old 09-20-2013 | 11:01 PM
  #2915
aturbotony's Avatar
Xceed had a clutch for the MTX4 and it came with a blue shoe. I had some in my parts box and I tried it. I don't know if they still make them
Old 09-20-2013 | 11:05 PM
  #2916
maver's Avatar
We must not underestimate the clutch in the whole of our MTX5.
In fact, it is so versatile and so little criticism that everything changes depending on the engine used and the track (eg xray is not as critical).
soft hard with engines that do not push up or fat will slip the bell wearing out and warming up the transmission.
l 'single index of a clutch well done is the' wear and tear of the strain. Always check after each session, the 'wear by measuring the distance bell-strain under 2 bearings, if the distance increases the friction is not good.
if the clutch and 'well done 99% does not dissolve the crown.
bye
maver is offline
Old 09-21-2013 | 05:30 AM
  #2917
NITTO550's Avatar
Thank you Maver for the information
NITTO550 is offline
Old 09-27-2013 | 04:51 PM
  #2918
OnRDPassion's Avatar
Just picked up a mtx-5 and pretty stocked on the purchase. Does anyone have a good set-up for GLARCR in Los Angeles they would not mind sharing? Also any upgrade parts that the car needs that would be considered an absolute have to? Thanks!
OnRDPassion is offline
Old 09-27-2013 | 08:53 PM
  #2919
sedan4life's Avatar
Greater LA - MTX5 set up Motonica Race
Front:
37F cut at 59MM
298 MM track width
-1 degree on outside camber and -.5 on the inside (wearing the tires flat)
Lt blue spring, one hole piston, 500 weight oil, middle shock tower hole
2.3 mm roll bar
150K oil with composite gears
upper arms in the top roll center position
+1 toe out on each side
ackerman in the middle position
one small clip in front for caster
5 MM ride height.
Rear:
40's cut at 61MM
299 track width
-2.5 camber on outside and 2 on inside ( wearing them with a little coning)
Lt blue spring, two hole piston, 500 weight oil, third hole from bottom.
2.4 mm roll bar
80 K weight oil with steel gears
6 MM ride height.
3 mm spacer on upper arm link and on inside lower hole
-1 toe in on each side
P37 body
As for upgrades, I only have 3. Steel diffs. a brace, and a 1-pc. eng. mount.
Hope this helps. See you at the next GLARC Club Race.
sedan4life is offline
Old 09-27-2013 | 09:07 PM
  #2920
Which brace are you referring to? I am assuming you mean a side brace and not the Mugen front and rear body braces correct? I am trying to find a side brace but am coming up with no luck. Any ideas?
Old 09-28-2013 | 04:14 PM
  #2921
sedan4life's Avatar
Yes, the side brace that eliminates the chances of the spur gears from stripping. You can make one from a turnbuckle with ball joints at each end. I've seen some made with carbon fiber, another one out of aluminum. Look thru the old postings in this thread, I've seen a lot of people posting pics.
Old 09-30-2013 | 07:11 PM
  #2922
NITTO550's Avatar
Oh man, mugen lovers are in for a real treat!!!
NITTO550 is offline
Old 09-30-2013 | 07:20 PM
  #2923
Why Rich ??? You won the Rc depot Regionals...lol...???
bertrandsv87 is offline
Old 09-30-2013 | 09:31 PM
  #2924
Bishop's Avatar
Car update?
Bishop is offline
Old 10-01-2013 | 05:06 AM
  #2925
GMartinez's Avatar
Originally Posted by Bishop
Car update?
Maybe a focus after the worlds as there is none at tbis very moment
GMartinez is offline
