Old 09-11-2013, 06:30 PM   #2896
NITTO550's Avatar
If u know what your doing and know what to look for, then it's a great car.
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 09-12-2013, 04:45 AM   #2897
maver's Avatar
Hello everyone, I state that they are in Italy, and even I, with the machine box and the new chassis and the whole bench, I had not broken the 2nd gear ..... but .......
in the last few months I found myself running on a very technical track and with much traction in these conditions and I broke as many as 3 crowns of the 2nd gear and every time I had to abandon the race due to lack of crowns.
I guarantee you that the car I keep it to perfection in all its parts, and now I think the shut in a drawer to go back (SOB) to the Xray.
as regards the folding of the frame I solved by moving the brake linkage above that of the gas in order to have the brake that work in push .... now restrains fine without kinking to the frame (see facebook Mugen MTX5).
maver is offline   Reply With Quote
Old 09-12-2013, 04:47 AM   #2898
maver's Avatar
sorry for my english, made ​​with google translator :-)
bye
Old 09-12-2013, 04:09 PM   #2899
NITTO550's Avatar
So maver, do you think the problem has to do with the twisting of the chassis on high traction ? Or the composition of the gears not being able to handle the stress associated with high traction ? Do you use a brace?
Rich D..
Old 09-12-2013, 04:47 PM   #2900
Seisick's Avatar
too bad some are still having issues stripping 2 speed gears
im on my 4 spur since I bought the car when It came out
and ive stripped those due to worn and overused pinions, heck I still
have old version gears! and no flex chasis whatsoever, so far
we have trackside chasis and shimos knack one that I see it as
the ultimate solution to prevent chasis flex!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 09-12-2013, 04:49 PM   #2901
google English is not bad it is as good as mine and I have to use spell check all the time hope you find the problem we don't have that much traction to do any damage pinions last 12 months of racing in Brisbane//aus
greg
greg.dawn is offline   Reply With Quote
Old 09-14-2013, 03:11 PM   #2902
Hi, I need some information. I have a choice betwenn 2 Mugen Mtx-5. First is model 2001 and the second is 2002. I think that the 2002 is a 2012 spec but i dont know , and i cant't find the difference between thes two model.
Does somebody know ??
Thank for your response.
Quebeker
Quebeker is offline   Reply With Quote
Old 09-14-2013, 09:28 PM   #2903
hi the later one has different diff /housing /screws and rear aluminium bulkheads and I think a few other bits and pieces and shoud have steel gears /diffs I think
greg
Old 09-15-2013, 08:56 AM   #2904
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Is there a newer version of this car coming out in the near future by chance?
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 09-19-2013, 12:47 AM   #2905
maver's Avatar
possible and the rumors say it will come out ...... we'll see.
Old 09-19-2013, 01:04 AM   #2906
maver's Avatar
the problem I had it only on a particular track, very technical with gear changes very fast and with a lot of traction .... in other tracks all goes' well.
my car 'with all the latest original parts mugen no tie.
I noticed that a lot depends on the type of clutch spring and how much you screw the ring, I am always convinced that it is not a matter of strength, but of heat (mixed torsion) in my opinion looking at the crown route is not sheared but purr.
who has the problem I propose to make the clutch with these measures:
gate locked by the book or at most 0.3 below.
bell play maximum 0.4
game final bell 0.1 maximum 0.2.
box spring.
to next race
Old 09-19-2013, 04:08 AM   #2907
NITTO550's Avatar
I see that the original clutch spring is too soft. Also loses tension fast. Right now I'm using the mugen ultra hard for the 1/8
Rich D..
Old 09-19-2013, 04:23 AM   #2908
Bishop's Avatar
The MTX5 clutch is a bit of a mixed bag, it's actually too hard with too much slip for some applications, and not enough slip for other higher power use, I have two motors where mine has never been that great, one low spec limited HP 12TG, where it just slips, and a 353-08 where it actually bites too hard at low rpm.
I guess this is the downside of really there being no choice of clutch shoe on the car, or lesser choice of spring, though I know you can run the harder springs.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-19-2013, 05:00 AM   #2909
NITTO550's Avatar
Right now I see 3 types of clutch springs. Hard, super hard and ultra. I like to tighten that spring until it slips THEN back off a bit. Clutch is always awesome! The problem with the second gear stripping is that the shifting has to be set later never early , especially on a technical track. If that motor goes straight into second coming out of a turn , it will strip. The clutch is actually aggressive .
Rich D..
Old 09-19-2013, 01:04 PM   #2910
Give us the mugen part no for these springs...
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
