Originally Posted by Dustin
(Post 12120560)
Looking for a good easy to drive setup for a medium sized track with some open and some tight sections. Are stock 200K/50K diff oils too thick for tighter tracks? Looking for some things to try, car seems edgy with stock setup.
Ok.....so there is no 2.0 sway bar???
Originally Posted by bigbank66
(Post 12123759)
Nope! |
(Post 12123759)
HI im missing the springs for the 2 speed clutch shoe just wondering can I use the springs set from the mtx4r as that's all I can find on ebay?
Would not be real hard to make them
Originally Posted by baldy
(Post 12124855)
i heard mugen made some for team drivers
Just need some piano wire the size you want the shape I very simple. Steve H |
I recon its worth a try
Originally Posted by Sakuraszero
(Post 12125320)
There are other places to get them too. Steve H |
the 2.2 sway bar works fine just lay your shocks down a hole
(Post 12124855)
(Post 12128358)
I am a team driver an i havent seen one....maybe im not high enough on the list...but if anyone know of a 2.0 rather than a 2.2??? Because if there is softer bar i want one:-):-)
Ok I have a question. On the steering knuckle there is that carbon fiber piece which has 2 mounting holes for the steering rod. One position is forward the other is back . What is this for,?
Originally Posted by NITTO550
(Post 12139921)
(Post 12139921)
Ackermann controls the difference in steering arcs between the front inside and outside wheels. The inside wheel always has a tighter arc in any corner. The amount of grip provided by the tires, in relation to the steering arc and speed of the car, create an amount of measurement called a “slip angle” for each wheel. For some tires you need a greater difference in slip angles between the inner and outer wheel and for some you need less. The angle of the steering rods can be changed by moving the steering rods inner mount position on the servo saver, or outer mount position on the steering blocks. 1. Inner Ackermann Position (servo saver) – Changing the forward/rearward position of the servo saver has the greatest Ackermann effect Position #1 (forward) – less Ackermann effect (steering rods more angled) Position #2 (rearward) – the greatest Ackermann effect (steering rods straighter) 2. Outer Ackermann Position (steering blocks) – Changing positions on the steering blocks is used to fine tune the Ackermann effect Position #1 (forward) – more Ackermann effect (steering rods straighter) Position #2 (rearward) – less Ackermann effect (steering rods more angled) NOTE: It is recommended to use more Ackermann effect in low-to-medium grip conditions and less Ackermann effect in medium-to-high grip conditions. AFM |
Thank you Maver and AFM. Great information!
http://i44.tinypic.com/33f6q69.jpg
mtx4 bumper assembly on the rear of the mtx5 chassis for protection\guard for the rear of the mtx5 car. |
| All times are GMT -7. It is currently 09:13 AM. |
