MTX 5
Old 06-27-2012 | 12:34 AM
  #2221
shanwright's Avatar
Talking two red eyes
Originally Posted by Chickentrader
Thanks for the compliment Greg, but Lars is not one-eyed! Everyone knows that.
Kindest regards,
Objective Lars.
Your right Lars, ....you're not one eyed, you have two eyes and they're both RED
Steve
shanwright is offline
Old 06-27-2012 | 01:34 AM
  #2222
hi LARS just though i would see if you were watching at least we love our own BRANDS EVEN IF YOU DRIVE THE WRONG ONE
GREG
at last we have lasted 1 hour final to win and some other cars finished refer to post ealier not hear over seas win
greg.dawn is offline
Old 07-02-2012 | 01:49 AM
  #2223
my mtx 5 driver is back in training from tomorrow back at track
greg
Old 07-02-2012 | 04:08 AM
  #2224
NITTO550's Avatar
I find that the mugen clutch shoes does not last very long. Does any other brand fit?
NITTO550 is offline
Old 07-02-2012 | 04:30 AM
  #2225
Bishop's Avatar
How long is not long?, and in what way are you finding that?, cause you do adjust the gap for wear over time, mine has done something like 10 meets or so I think.
And to directly answer your question, other brands likely won't fit as the clutch is quite unique, but A-Plus or someone like that make a 5 clutch kit I think, though I read elsewhere the brand quality is crap.
Bishop is offline
Old 07-02-2012 | 04:46 AM
  #2226
NITTO550's Avatar
I ran two races and 2 practice sessions , and I always reset my clutch before each outing. The X-ray surely lasted longer. I was hoping that some other high quality clutch shoe would fit. Im not interested in using and aftermarket clutch set like a-plus. I'm not knocking it cause I've never tried it but the mugen clutch is fine, just wanted other shoe options
NITTO550 is offline
Old 07-02-2012 | 06:28 AM
  #2227
djiewie's Avatar
I must be doing something wrong here. My xray nt1 clutchshoes have lasted me 2 years already. i am using two separate clutches on 2 engine`s though but they already seen several engine`s. never knew they suppose to wear faster
I use the yellow normal clutch not the dynamic, could be the reason.
maybe they (xray that is) fit the mugen
djiewie is offline
Old 07-02-2012 | 06:40 AM
  #2228
I have also the same prob with the clutch. After a 5-10min session I have more endplay in my clutch.
SebO is offline
Old 07-02-2012 | 12:23 PM
  #2229
NITTO550's Avatar
Your right, the xray standard clutch does last a long time. You could run it for a complete summer. Then again the mugen clutch shoe is almost 1/3 the price of an xray shoe.
NITTO550 is offline
Old 07-02-2012 | 12:27 PM
  #2230
NITTO550's Avatar
The mugen clutch can tend to be a little aggressive, so you must stay on top of your end play and thrust bearing. This is why i like to reset my clutch before each outing.
NITTO550 is offline
Old 07-02-2012 | 01:39 PM
  #2231
NITTO550's Avatar
Ill try the xray high dynamic clutch shoe as soon as i get my hand on one. And what screws are you guys using to close up the diff with.
NITTO550 is offline
Old 07-02-2012 | 02:54 PM
  #2232
shanwright's Avatar
Smile Diff screws
I've being using titanium M2.6x10 3 racing sell them.
The trick here is not to over tighten them!!
If you do you will distort the diff end cap and they will leak like crazy.
The last diffs I built, i also add a smear of gasket sealer too.
These diffs have not leaked.
Steve H
Old 07-02-2012 | 03:03 PM
  #2233
shanwright's Avatar
Default Thrust Bearing end stopper
Just a quick check!
Is your thrust bearing end stopper concentric ?
Not sure if you are running the t2002 kit. In The older kit this part was faulty.
But I would check all new ones too.
It can be hard to pick up in some it was only a small amount but it will make shoes wear quick.
Steve H
Old 07-03-2012 | 12:18 AM
  #2234
we ran 1/8 red one in 4r but i am not shore whether the mrx5 make a red one //how hard are you on cold clutch we got about 15 liters 6 months out of our first yellow one //we always lot it warm up or it will slip//blip throttle a bit till it grabs properly
greg
grandson //my driver is back racing again we did about 2 hours practice to day and car is still in one piece only one crash little one no damage
Old 07-03-2012 | 04:37 AM
  #2235
NITTO550's Avatar
Originally Posted by shanwright
Just a quick check!
Steve H
I read about the bearing holder being drilled off center, and i checked for that . I didn't see a problem, plus i only stripped 1 gear, on my initial runs, but its been great since then. I will double check since you mentioned it. I think the xray one is the same size. Thanks again.
NITTO550 is offline
