MTX 5
Old 03-16-2012, 11:21 AM
  #1861
gotmotor's Avatar
Originally Posted by Perez
is that another Shing production?
Think I might be able to make it to the Montica race next weekend , if its not raining...
Lol no, found it on Pietsch's page on FB, after running the car I don't think I need it, the car works great.
gotmotor is offline
Old 03-16-2012, 11:59 AM
  #1862
KMW
KMW's Avatar
Just weighed my car with 1450 life, one low profile servo (throttle), some ti screws, steel rear diff and it came out to 1705 grams!!
It seems like the only option for me is maybe finding a 700 mah life battery (if one exist), Titanium pivot balls, and a low profile steering servo. I am not a big fan of the Low profiles for steering as they seem a little too slow for my taste but if i'm gonna make it anywhere close to 1525 , ive gotta loose weight!
Perez, why are you trying to get down to 1525g?
KMW is offline
Old 03-16-2012, 05:52 PM
  #1863
YBSLOW's Avatar
Default MTX5 Brass Motor mounts
Info at: [email protected]
45 grams
Attached Thumbnails MTX 5-imag0563.jpg   MTX 5-imag0564.jpg   MTX 5-imag0565.jpg   MTX 5-imag0566.jpg
YBSLOW is offline
Old 03-16-2012, 10:27 PM
  #1864
Jason Smith's Avatar
The numbers I see on Roars website are 1725 minimum for nitro TC. Looks like your light already unless I'm missing something.
Jason Smith is offline
Old 03-17-2012, 12:51 AM
  #1865
Perez's Avatar
I was under the impression that ifmar is going to change the weight to 1525. Am i tripping?
Perez is offline
Old 03-17-2012, 01:07 AM
  #1866
has anyone got a complete listing of the bearing sizes used in the MTX5?
...or a website to a reputable shop that sells a complete set of ceramic bearings?
i checked out acer bearings and it looks like it isn't a fulls et of bearings in the mtx5 kit
...boca bearings do not have a full set of mtx5 bearings available.
TomB is offline
Old 03-17-2012, 06:36 AM
  #1867
Bishop's Avatar
45 grams
Sweet...
http://abec35.com/categories/Ceramic...s/Mugen-Seiki/
I think you will find most 'sets' leave out many of the smaller bearings, though you can usually get them separate, at more cost of course.
Bishop is offline
Old 03-17-2012, 07:17 AM
  #1868
lil-bump's Avatar
Trader Rating: 89 (100%+)
Roar's minimum weight limit is still 1725 grams. For now; the 1525 only effects the EFRA block(Europe). I don't believe IFMAR has ruled on this change
Pass you soon...
lil-bump is offline
Old 03-17-2012, 10:04 PM
  #1869
Originally Posted by Bishop
Sweet...
yeah i've seen the ABEC bearigns. they are missign many bearings.
i was hoping to get a bearing size listing to check with my local bearing shop.
anyone have a full list of bearing sizes for the MTX5? they aren't listen int he manual.
TomB is offline
Old 03-17-2012, 10:30 PM
  #1870
Arahawak's Avatar
Trader Rating: 32 (100%+)
I think ABEC35 provides the essential bearings for drivetrains.. the 'left out' bearings dont really help in 'moving' the car.. the XCOs are some of the smoothest bearings i ever used.
Arahawak is offline
Old 03-18-2012, 03:02 AM
  #1871
i think the ABEC kit is missing some of the 2 speed shaft bearings and the clutch bearings right?
TomB is offline
Old 03-18-2012, 03:37 AM
  #1872
Arahawak's Avatar
Yes, which you can get separately...
I feel those bearings may have loads higher than the others, so I personally use the cheaper GC3 ZZ metal shield ceramics for them..
Arahawak is offline
Old 03-18-2012, 04:05 AM
  #1873
ceramic bearings can carry as much load as steel bearings. They are used in nitro engines which exert more force than a 2 speed shaft, so ceramics on the shaft shouldn't be an issue.
the ABEC bearings are quite pricey and you don't get a full kit of bearings. I also read here or on another thread that the quality is not consistent
TomB is offline
Old 03-18-2012, 04:35 AM
  #1874
Arahawak's Avatar
I am happy with mine so far.
Arahawak is offline
Old 03-18-2012, 06:51 AM
  #1875
Seisick's Avatar
Pass you soon...
Correct but from 2013 onwards
Seisick is offline
