Rc10ntc3
#9031
Trader Rating: 21 (100%+)
With the right setup, the NTC3 can still be competitive in some tracks (mainly short/medium tracks). As I see it, the car has 2 main issues:
- the diff gears cannot handle the power of today's motors (especially on high traction and bumpy tracks),
- the very limited tuned pipes availability.
If these 2 issues were solved (and the parts durability increased), I believe the car would be competitive in almost all tracks.
#9032
NTC3
when you compare the car with the CD3 how do you think it goes? and an STS D3R it work well on it?
Joe F
Joe F
#9033
what is the best tuned pipe for the ntc3 ?
#9034
#9035
Joe F
Joe F
I have had both NTC3 & CD3/FW05R...
Both cars work really well and drivetrain is very efficent. Advantage with the Cd3/Fwo5 is gas cars have a tentancy to squat at the rear under accerleration and when this happens it is less likely to pick up rocks in the spurs as the 2 speed is in the centre. Also i don't know if you can prove it or not but the airfilter position on the NTC3 is sitting right in the hot air as it exits the engine heatsink. This all said both cars worked really well and are competitive with those belt drive chassis's.
I hope this helps, i would check to see which car you can get parts easier in your local area.
BB
#9036
Originally Posted by meinie
The Werks Racing one-piece pipe.
http://werksracing.com/product.do?sku=WRX6610C
Would like to give the pipe a go, I'm using the early version of the One piece rear exhaust Turbo pipe for the NTC3 from RDLogics this pipe has been good but damaged it last race, was thinking of getting a nother RDLogics or FT dual pipe or the OFNA pipe or the Werks Pipe but I have not made up my mind get
#9037
I have an NTC3FT for sale fitted with a Top .12 which has only just been run in. Plus loads of spares including a K-Factory chassis. See attached pictures. Anyone interested PM me and I can let you have more details.
#9038
Yes, I've run the pipe quite a bit. Best I've tried. Really suits high-winding engines.
#9039
Originally Posted by Sheer29
Meinie have you used the Werks pipe it's a nice looking pipe but could not find any one that has used it and I have not found much info on the pipe
#9040
Originally Posted by Uneke
In my opinion this is the best pipe for the TC3 but it is kinda fragile.
#9041
i have 2 questions i have a 5 cell battery pack its the flat in the battery tray do u place the batt closer to the center drive shaft or away at the edge of the chassis. how do u know when a track its short medium or big i use my ntc3 at revelation u can check pics at www.revrace.com i forgot how big it is i think 200 ×180
#9042
For anyone that might be interested, I bought a NEW front one-way for my electric late model based on a TC3, and it was a supposed universal fit for all Associated TCs, but the outdrive cups are longer and shallower, and they don't fit in my car. The unit is a NTC3 one-way and is brand new.
I need an electric HD version, so if anyone happened to do the same thing I did and bought the wrong one, I'd be interested in trading for the correct drive cups (the center housing and ring gear are the same).
PM me here or hit me on AIM at upon3 if you want to work out a trade.
doug
doug
#9044
Originally Posted by graphiteman
I have an NTC3 that I have raced twice. Does anyone have a good tip for the aluminum shocks? Without the bladders, I really dont care for the end-result. Any suggestions? Do you guys run the stock shocks, or do you swap them out? Any help is appreciated.
#9045
