Rc10ntc3
#7531
It's supposed to move - it wouldn't be an anti-roll bar (sway-bar) if it didn't.
It should pivot, and even slide back and forth. It should not move vertically.
Using a shim or small washer will make this happen quite well.
If you cinch it down so that it doesn't move at all, it's then merely a spring, not a sway bar.
#7532
#7533
Originally posted by macnkitty2002
ok, track width then.
how do you do it? pictures would help if you can provide them.
In your kit, there should be a plastic tool (part #1719), its used for measuring the standard trackwidth it also doubles as a ride height tool.
When you adjust the trackwidth, make sure that your CVD`s are still seated properly in the outdrive cups.....if you go too wide a trackwidth the CVD`s will come loose.
Cheers
#7534
Oops...forgot...
PAGE 10, Section 5 of the manual will show you how to set the trackwidth...has pics.
Cheers
Cheers
#7536
this is a second hand car, so no manual or any such tools
dude.download at rc10.com.u need it
#7537
Here's a pic of the blade.
#7539
dude, i tried to find it on the team associated site, no results. could you be a kind fellow and please find the url for me?please?
#7541
no problem!
#7542
Team Associated`s website-
www.teamassociated.com
They have setup sheets there, which you`ll find handy if you havent got a manual.......also some race setup sheets from Barry Baker and Co.....you`ll need Adobe reader to view them and rpint them.
Cheers
Cheers
#7544
That's Poncherelli from Chips. CHEESE
