Rc10ntc3
#8822
i think the ntc3 one-way shims will fit the k-factory one-way.
#8823
There is 2 sizes for the shims, the standard shims to suit the diff & the oneway(silver colour) & the odd ball shims to suit the Heavy Duty oneway (Blue). Never seen a K-Factory oneway for the NTC3, but if it doesnt take the same shims & bearing as your diff you could be in some trouble. They have a hybrid metric & imperial bearing, I cant remember the sizes but the ID is metric & the OD is imperial. I never found anywhere I could buy replacment bearings, shims or outdrives. I think I ended up with 4 or 5 oneways in the end just for the bearings.
#8824
here is the one-way:
http://www.kfactoryracing.com/produc...1244&pageNum=6
#8825
Sorry, I dont know the part number. I dont think you can buy any of the oneway peices seperatly (except the gear). Your best bet would be to go to a machining shop & have some made. There was a discussion on this thread maybe 6 months ago on the bearings & shims, I dont remember the outcome as I had already decided to move over to Serpent at that time.
#8826
Need Help with K Factory motor mount
Hello, just installed K Factory push type 30mm clutch on my ntc3 and was wondering if anyone had any feedback on it, also noticed that the stock engine mount screws do not fit the k factory mount I believe that they are 5/32 and 8/32 i just wish i could find the right head types so that i dont have to mutilate the chassis and get my OS TZ .12 ...broken in.........
#8827
The k-factory clutch is pretty easy to use, the instructions go into detail on how everything should be so setup like it says and you should be right.
Try to find to some good lubricant to put on the thrust bearing, maybe molyboeum grease or ceramic grease something like that so it don't crap itself .
It is good clutch though i haven't had any problems except when i overtightened it.
#8828
#8830
It's in the works but don't expect it untill late this year or early 07
#8831
Registered User
Pressure: I set the k push clutch up loose, tight and everything and always had thrust brg troubles. I bought a sealed brass thrust brg off ebay and no more problems ! clutch works very well and no brg failures since the change over. I can't remeber the guy or companys name but they are always on there do a search. Bob
#8832
#8833
Originally Posted by AndyT ©
Its also worthwhile to take out the hinge pins and give them a polish.....this helps prevent any binding and frees up the suspension a bit.Cheers
#8834
Originally Posted by Old Skool
I was cautioned that the black coating on the hinge pins is there to prevent corrosion, and polishing them is not recommended.
#8835
