Rc10ntc3
#8761
Originally Posted by wayne
thats all well and good, but what is going to happen to parts support for the ntc3...
#8763
There`ll also probably be some parts "overlap" between cars....things such as spur/pinion gears etc probably wont change.....unless of course its a totally different design entirely.
#8765
Originally Posted by macnkitty2002
has anybody tried the 3racing carbon fiber/alloy front suspension support?
has anyone tried the associated one chamber ntc3 pipe ???
#8768
Originally Posted by ae_ntc3
no but im getting the rear kfactory suspension support.
#8769
at the moment i am using the mielke pipe and i have a big race meeting coming up in a week.the rd logics pipe has been ordered but i do not know if it will get here in time so what is the second best pipe ??
i found the ft kit blue pipe to be good down bottom end but restricts the motor top end.
i am running a sirio evo3 and mine is the slowest towards the end of the straight.
#8773
so the rdlogics pipe will not work at jgir ????
#8774
a good mod you can try on the factory kit blue exhaust is cut the header pipe about 2-3mm shorter and reposition the pressure line hole further towards the mounting wire end of the pipe.
this is done by drilling another hole near the mounting wire side of the pipe and blocking the old hole with kneed-it putty.this helps stop the fuel tank from frothing.
