Rc10ntc3
#1786
PIPE
Well, had some good news and bad news this past weekend about the JB WELDED pipe. Good news is that the weld held rather nicely. Bad news is that the rather large dents rally hurt the engnes performance. I could only ease the car to full speed or else the engine would blurp. Since this is my first year racing, I never expiremented with pipes. Just knew how well my combo was running. Please correct me if I a wrong, its must be because the air flow is being hampered on the way out and not free flowing. I found myself in a visious circle. If passed, I hadn't the power to overtake most times that I am used to. So I would try to make up for it on the turns. But going in faster than normal, causes a whole bunch of other problems. Looks like the 2 chamber pipe for me next. Is the differance really noticable? I ask cause I may be able to get the stock pipe really cheap.
#1787
LIVE CHAT
Right has anyone noticed the live chat? well why is it everytime i go on no-one is there? .... what i propose is everyone goes on tomorow 27th nov at 8pm (grenich mean time) and everyone can talk about there car LIVE instead of writing in this forum and waiting for a reply!
plus if it is a sucess more times can be arranged! what do you think 8pm sharp!
#1790
I'm still deciding on what car I should buy. But I think because my budget is not so high and I want the least amount of hassle possible, I'm getting very close to getting an NTC3 RTR. I say less hassle, because my local LHS supports the NTC3 primarially, parts are abundant, and I dont think I'll ever have a problem with support. So based on that, I'm assuming I'll be making a pretty sensible choice if I was to go with the NTC3. My only question is this: When I want to ugrade my NTC3 RTR to kit spec, how easy is the upgrade, what parts would I need, and how much would the upgrade be about? Thanks
#1791
I think the only major upgrades would be threaded shocks, MIP CVD's, and the 2-speed kit. Then you'd be very close to the Team kit (if not the same). I would guess $150-200 depending on where you shop.
#1792
rc10tc3
could i get a good working set-up (camber,toecaster droop)
and tire shore for crystal and revelation raceways
#1794
#1795
Sirio 12Trp
Hi Corse-R,
Have you broken in the sirio 0.12 ? How is the performance comparing with JP or RB and stock Nova rossi ? let me know...thanks
#1796
You'll need this and servo washers.
http://www2.towerhobbies.com/cgi-bin...P?Q=1&I=LXD999
Originally posted by NEMMITH
Oh one more thing can anyone tell me what parts I will need to do the mod for the shock towers?
#1797
Thanks , rcruv.
#1798
tc3
i've already have downloaded and printed off copies of barry's
set-ups as well as the team drivers ,but there nothing for revelation. and there are alot of tc3 drivers at that track so i though that someone could give me a good set-up they like to run there...
#1799
Re: Sirio 12Trp
Carburation is very responsive to the adjustments, with their price is a breeze using it. Power can go upwards with a little of porting, but at this moment I don't feel the need to.
Since the last time I used the JP I ported the manifold and cut a little more, maybe in the same conditions, JP now is slightly faster, but I'll stick with the Sirio and keep the JP for 'when the times are tough'.
I don't know, but almost all the engines like the 21/27 combination. AE sticks to being very conservative when advising for ratios. Only needed to use the 20/26 one time and few times I used 21/26 with the RB (very strange motor, needs 'some help' for scream on the backstraights, expecting the 215 model is better than the 210).
#1800
Re: PIPE
Originally posted by CHUCKMANDO
Well, had some good news and bad news this past weekend about the JB WELDED pipe. Good news is that the weld held rather nicely. Bad news is that the rather large dents rally hurt the engnes performance. (....) Looks like the 2 chamber pipe for me next. Is the differance really noticable?. Thanks
