HPI R40 Nitro Car Forum
Is there somebody interested in my allmost ready R40 with a lot off spares, tyres, jump box and bodyshells. The only thing you have to have to make it drive is a transmitter and a receiver.
The car is in great shape!
pm or email me for any questions, pictures and i will answered them as soon as possible
Edwin
[email protected]
Edwin
[email protected]
Originally Posted by coolson
Oh... I though the charger would auto detect the number of cell. and the maximum number i can change on that number is 5.
if that number means number of cells. How come I can't set the number which bigger than 5. As the manual said you can charge NiMH from 1-14 cells.
Thanks in advance!
Thanks in advance!
Originally Posted by CraigM
Ask rapidroy, he's just done this. i'm not sure how much difference the new layout makes but the lightweight 2 speed is a must have
On another topic, I keep going through outer clutch bearings (the flanged one inside the bell). Does anyone else have this problem? I assume this is because they take the sideways force from the clutch engagement, but is there anything I can do?
Originally Posted by bucknuts
Make sure the shims are on the outside of the bearing so that the inner thrust bearing washer hits the outside (flanged) race of the clutch bearing.
I had wondered about this, but I'm pretty sure the instructions show the shims between the thrust and the bearing. Will swap em around, bring the clearance right down (it's pretty minimal at the moment) and see how it goes
R40?
Are the 0.8 spurs standard?
From your signature it seems that you do.
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
why are you buying Mugen pinions?
Can someone e-mail me the setup sheet? My Adobe reder wont let me open the one on the site.
The PDF set up sheet on the HPI site, I tried 2 PCs and it wont open it, some error.
was going to pick up some of these but want to make sure they'll fit
The mugen gears are not the same as the R40 and will not work on the R40. Maybe with a couple off modifications.
