HPI R40 Nitro Car Forum
#6811
Originally posted by HarKonnenD
Yes, he is. HE's up her for the moment though. Just wondering. No worries about the pic as I won't need it for any time soon. Trying to save my $$ for the real car.
later....
#6812
Front lower suspension mount
AMG, would be very gratefull if you could scan the supplement, seems I either lost mine or wasn't included, although I don't recall ever having seen one. Cheers
#6813
Re: Front lower suspension mount
Check this picture of a 2004, its in the lower position.........
#6814
mine came with supplementary sheets for one way graphite towers etc, but no mention of fls settings or any other settings for that matter.
While we're on the topic of meager instruction manuals the rear diff ball bearings fit into adjustable mounts, stock setting is vertical, have you any idea what these are for?
#6815
Re: Re: Front lower suspension mount
Originally posted by AMGRacer
Damn I cant find my 2004 supplements. Did yours come with a normal manual with supplementary sheets, or a 2004 specific manual...............? I will keep looking.
#6816
Originally posted by KLANDERMAN
KOOL is he also into R'40s.... Ask him where he is from in Guatemala, Im from the city...
later....
later....
Performula- I agree the purple chassis has got to go. However when I ding mine up a bit more I'll get it. The Oneway diff and solid rear axle are coming in.
#6817
OK HARK, no problem!!! Are you going to place the oneway, or the solid axle in the front, or are you going to use the the oneway in the front and the solid axle in the rear?? I'm just asking because mine is set up with the solid axle in the front and the stock diff in the rear... I hope I didn't misslead you into thinking I had the solid axle in the rear ok....
#6818
Naw, I knew you had it in the front. I just wanted to test out that setup with both items. My car moves pretty quick regardless, but it does feel a bit heavy. Not that it's a problem, but eh still. I'm ordering stuff little by little since I have a real car on the way. My friend got the LW chassis from Bruckners for $64, while Tower has it for $74+. I'll compare how much my LHS can get it for and if it's less than tower I'll do it.
#6819
Hi Guys,
Can anyone tell me where I can order some spur/pinion (0.8) for light weight 2 speed? The stock light weight 2 speed came with gears that's a little too tall for our track... so I need to lower them for more acceration. Thank you.
#6821
Originally posted by gfd2726
Hi Guys,
Hi Guys,
Here is the link you need
http://www2.towerhobbies.com/cgi-bin...I=HPIC1180&P=Z
Check at the bottom for the LW pinion gears, dont get the colored ones, those are for the 1.0 tranny
#6822
Check www.towerhobbies.com
#6823
I know lol...
#6824
Artificial I- you are the one who has a PROCEED?
#6825
I just placed an order from tower for some gears! Thanks Artificial-I & KLANDERMAN!
