HPI R40 Nitro Car Forum
#3121
PW is:
rctech
rctech
#3122
email address or mobile #?
#3123
Originally posted by AMGRacer
Does anybody know what using the +2 rear blocks, or the front hingepin mounts flipped upwards does? I think that it is supposed to raise the roll centre of the car, but I am getting some conflicting information from various sources...........
#3125
battery mod
Thanks guys for the battery mod info.
Domo, nice pics... the mod job looks very clean. It looks like you cut half your battery box off... I assume so the battery door still has something to bolt on to, right?
AMG, thanks for the input on the RX box... I paid $75 for it, better to take care of it.
BTW, does anyone race in Los Angeles? Revelation Raceway, Crystal Park, or Sun Valley?
#3126
Re: battery mod
Yeah, I cut 3/4 of the box to be exact. I plan on shaving off more unneeded plastic later this week.
#3127
how do you figure the final drive ratio? also where are good websites for aftermarket parts?
#3128
Originally posted by fastharry
I got a better than one than that...On that same tree,73479,what are those pieces #3 on the tree?
I've tried matching those 2 holes up with everything....
Laters,
Jeff
#3130
Re: Re: battery mod
Originally posted by DOMOisCOOL
Thanks.
Thanks.
I removed the box altogether. I am running the trinity pack light weight pack, sho gooed directly to the battery plate on the chassis. I slid it forward a bit to clear the back of the gas tank. I took two screws/nuts and use them to hold the battery plate to the chassis.
It gives you a lot more room to run the wires to the rx box and makes it easier to keep them clear of the steering servo. I used a couple of zip ties to keep the wires neat.
I have a switch with a charge lead so I can charge no problem. If I need to get to the battery I can pop the tank easily (great feature of the r40) and have access to the battery or the nuts to remove the battery plate.
If I have to change the battery the sho goo can easily be removed to seperate the battery plate and the rx pack.
I'll try to post some pics in a day or so.
#3131
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally posted by Proteus
LOL! It took me awhile to figure that one out too! I've tried one and I've tried both, but I like it better without. I'll keep you guessing for a little bit longer. I'll give you a hint. It's for the roll center....
Laters,
Jeff
Laters,
Jeff
#3132
4 gear diff mod shafts
hey all, I know that this was covered a while ago and that hpi makes a kit for the diff mod. But I searched on the forum and was not able to find the shafts that people were using to complete this mod, I do remeber that some were using ofna shafts but I was not able to recall which cars they were from.
thanks all Jason
thanks all Jason
#3133
Re: 4 gear diff mod shafts
thanks all Jason
thanks all Jason
http://www.rctech.net/forum/showthre...632#post721632
#3134
Re: Re: 4 gear diff mod shafts
Originally posted by wangcc61
Try the post here
Try the post here
thanks Jason
#3135
PTI 2005 Mustang body
In case anyone was thinking of getting the PTI Mustang body... it doesn't fit on the R40, or the Nitro RS4 for that matter. The body is about 1/2" too short. I suppose you can shave the foam bumper down... but, you'll sacrafice some front end protection. So, now that the body is all painted and ready to go... it'll just be sitting on my bookshelf.
What bodies are you guys running out there? The Stratus seems to be the most popular around my home track.
